{{{{okada project ignition in stock and ready to go}}}
Okada Projects' Plasma Direct
The Okada Projects' Plasma Direct is a direct coil replacement specially designed and developed to work as a secondary ignition amplifier increasing spark amperage 100%. Plasma Direct Coils produce 4 times more spark energy than stock coils, creating a faster flame front and quicker light-off of the fuel mixture kernel to complete combustion.
With Okada Projects Plasma Direct installed on your 03-06 Evo 8 & 9, you can feel increased torque in low RPM and get more horsepower in higher RPMs. Installing Plasma Directs is an easy direct bolt-in to the engine, no splicing or cutting into stock wiring.
![](http://www.jscspeed.com/images/products/42ddba81d90e09f8.jpg)
Retails for $599 pm me for best price!
Okada Projects 03-06 Evo 4-9 Plasma Quad Pac
Okada Projects, an innovator in the field of Ignition Systems for modern internal combustion engines, has released its newest product, the Plasma QUAD PAC. Four pieces of Coil-Over-Plug ignition coils and an electronic control system replace the original OEM waste spark system for the Mitsubishi EVO 8,9 and other vehicles. Extensive testing has proven that Plasma Quad Pac delivers extreme high voltage individually adapted to the need of each cylinder under high turbo pressure load conditions.Plasma Quad Pac comes with 4 coils, an electronic control unit and complete mounting and wiring harness parts. All wires are “plug and play”; no cutting is required; just install and enjoy the extra reliable horse power and increased torque with no misfire under high pressure load.
Compared to the original Mitsubishi waste spark system, secondary spark voltage is increased by 30%. Increased spark current allows higher boost pressure without misfire. Four individual Plasma Direct Coils will bring the spark energy directly to the spark plugs and the engine will perform well to the highest RPM.
Plasma Quad Pac is a reliable Okada Projects quality product and fits Mitsubishi EVO Models 4,5,6,7,8 and 9.
Plasma Quad Pac is fully compatible with all other Okada Projects Ignition Parts.
![](http://www.okadaprojects.com/usa/images/p_quadpac/plasmaquadpac_top.jpg)
![](http://www.okadaprojects.com/usa/images/p_quadpac/quadpac_componentx165.jpg)
Retails for $799 pm for best price!
