FID: Evo 7-9 Small Battery Mounting kit
Old Jul 14, 2010 | 04:11 PM
FiD-Turbo.com's Avatar
FID: Evo 7-9 Small Battery Mounting Kit
Forced Induction Development (FiD)
The FiD Evo 7-9 small battery mounting kit allows you to replace your heavy bulky factory battery with a lightweight Hawker/Odyssey mini battery. The kit significantly reduces weight and allows space for better intercooler pipe routing. Tray mounts to factory mounting points allowing for an easy bolt-on installation.
Features:
-Designed to fit the Hawker/Odyssey PC680 size battery, may fit others of similar size.
-CNC machined tie-down and tray from 6061 billet aluminum.
-Laser cut and CNC bent 6061 aluminum mounting bracket.
-Battery tie down secured w/ 3/8" flush-mount socket cap screws providing a clean smooth appearance.
-Black anodized finish w/ engraved FiD logo.
-Available with or without Odyssey PC680 mini battery.
Click link below to order online:
PART #: FID-EXT-30001 (FiD Evo 7-9 Small Battery Mounting kit w/o battery)
PRICE: $149.95 + S/H
Evo 8/9 FiD Billet Aluminum Vacuum Manifold Kit - Available in Black and Red
Specifically designed for forced induction applications that require multiple vacuum sources.
Features:
-Precision CNC machined from 6061T6 billet aluminum.
-Laser cut and CNC bent aluminum mounting bracket designed to mount to the front strut tower brace on the evo 8/9.
-Has six 1/8" NPT ports for items such as fuel pressure regulator, blow-off valve, MAP sensor, boost controller, boost gauge, and any other engine components that require a vacuum source.
-Has two 1/4" NPT ports for vacuum supply and/or source.
-Available in two different colors : Black, Red.
Fittings include:
(qty 1) 1/4"NPT Hex Socket Plug (Brass)
(qty 2) 1/8"NPT Hex Socket Plug (Brass)
(qty 2) 1/8"NPT x 3/16" Hose Adaptor (Brass)
(qty 2) 1/8"NPT x 1/4" Hose Adaptor (Brass)
(qty 1) 1/4"NPT x 1/4" Hose Adaptor (Brass)
PART #: FID-EXT-30010 (Evo 8/9 FiD Billet Aluminum Vacuum Manifold Kit)
PRICE: $59.95 + S/H
Old Jul 17, 2010 | 11:45 AM
bump.
Old Jul 20, 2010 | 12:33 PM
evo-boost's Avatar
bump
Old Jul 20, 2010 | 06:41 PM
itr.#1446's Avatar
will the battery tray fit a braille battery?
Old Jul 21, 2010 | 07:37 AM
Unfortunately our battery tray will not fit any of the braille batteries that we are aware of. Below is the spec on the dimension of the Odyssey PC680 size battery. If braille does make another battery in the same dimension as the PC680 shown below, then it should fit.
Length 7 1/16"
Width 3"
Height 6 9/16"
MrC
Old Jul 22, 2010 | 08:24 AM
evo-boost's Avatar
Items are IN STOCK and ready to ship.
Old Jul 23, 2010 | 01:54 PM
evo-boost's Avatar
bump
Old Jul 26, 2010 | 08:20 AM
evo-boost's Avatar
bump
Old Jul 27, 2010 | 11:15 AM
MR DSM IX's Avatar
bump for good products ;-)
Old Jul 28, 2010 | 11:43 AM
evo-boost's Avatar
Old Jul 29, 2010 | 01:15 PM
evo-boost's Avatar
bump
Old Jul 31, 2010 | 08:11 PM
evo-boost's Avatar
bump
Old Aug 3, 2010 | 09:22 AM
evo-boost's Avatar
bump
Old Aug 9, 2010 | 12:56 PM
evo-boost's Avatar
bump
Old Aug 12, 2010 | 09:39 AM
evo-boost's Avatar
bump
Quick Reply: FID: Evo 7-9 Small Battery Mounting kit
