FiD: Fuel Rail, Motor Mount, Mini Battery, Vac Block & More...
Forced Induction Development (FiD)
Evo 8/9 Tubular Stock Replacement Turbo Manifold
The Forced Induction Development (FiD) - Evo 8/9 Stock Frame Turbo Manifold was independently tested against a competitor's OEM ported manifold on the dyno and the results were impressive with a significant gain of 20+whp at peak power over the ported manifold.
Read the comparison here: https://www.evolutionm.net/forums/evo-dyno-tuning-results/508829-fid-evo-8-9-tubular-stock-replacement-vs-ported-oem-turbo-manifold.html
Our efficient tubular header and merge collector design promotes quick spoolup and maximum power to take full advantage of the stock and stock-frame turbo. We build our tubular equal-length manifold utilizing 3D CNC machined billet 304SS head flange. The head flange features a 3D transitional ports (oval to round transition) with counter-sunk port opening on the front to provide strength and support for the welded runners. The backside of the head flange features a machined cut-back to help minimize warpage during welding and promote better gasket sealing. The head flange is fully decked for flatness prior to machining as well as after the manifold is fully welded. This is the only way to ensure a perfect sealing surface for the exhaust gasket. In addition, the manifold is fully Tig welded and all connections are multi-pass welded and fully back-purged to eliminate any chances of joint fractures.
Features:
•20+ whp & 10+ wtq gain over competitor's popular oem-ported manifold
•100% 304 Stainless Steel thick-wall equal length manifold with narrow angle twin scroll merge collectors.
•304 Stainless Steel CNC machined 3D header flange (1/2" thick).
•304 Stainless Steel CNC machined Turbine Inlet flange (1/2" thick).
•Multi-pass tig welded and fully back-purged.
•Header flange and turbine flange decked pre and post welded.
•Clears all accessories and sensors, does not require extra heat shielding.
•Carries Lifetime warranty to the original purchaser
This manifold includes an optional SS npt egt bung per customer spec:
Click link below to pre-order online:
PART #: FID-TBM-30001 (FiD Evo 8/9 Tubular Stock Replacement Turbo Manifold)
Evo 7-9 Odyssey PC925 Battery Mounting kit
The FiD Evo 7-9 Odyssey PC925 battery mounting kit allows you to replace your heavy bulky factory battery with a lightweight Hawker/Odyssey mini battery. The kit significantly reduces weight and allows space for better intercooler pipe routing. Tray mounts to factory mounting points allowing for an easy bolt-on installation.
Features:
-Designed to fit the Hawker/Odyssey PC925 size battery, may fit others of similar size.
-CNC machined tie-down and tray from 6061 billet aluminum.
-Laser cut and CNC bent 6061 aluminum mounting bracket.
-Battery tie down secured w/ 3/8" flush-mount socket cap screws providing a clean smooth appearance.
-Black anodized finish w/ engraved FiD logo.
-Battery not included.
Click link below to order online:
PART #: FID-EXT-30002 (FiD Evo 7-9 Odyssey PC925 Battery Mounting kit w/o battery)
PRICE: $175.95 + S/H
Evo 7-9 Small Battery Mounting kit
The FiD Evo 7-9 small battery mounting kit allows you to replace your heavy bulky factory battery with a lightweight Hawker/Odyssey mini battery. The kit significantly reduces weight and allows space for better intercooler pipe routing. Tray mounts to factory mounting points allowing for an easy bolt-on installation.
Features:
-Designed to fit the Hawker/Odyssey PC680 size battery, may fit others of similar size.
PART #: FID-EXT-30001 (FiD Evo 7-9 Small Battery Mounting kit w/o battery)
PRICE: $149.95 + S/H
Evo 8/9 FiD Billet Aluminum Vacuum Manifold Kit - Available in Black and Red
Specifically designed for forced induction applications that require multiple vacuum sources.
Features:
-Precision CNC machined from 6061T6 billet aluminum.
-Laser cut and CNC bent aluminum mounting bracket designed to mount to the front strut tower brace on the evo 8/9.
-Has six 1/8" NPT ports for items such as fuel pressure regulator, blow-off valve, MAP sensor, boost controller, boost gauge, and any other engine components that require a vacuum source.
-Has two 1/4" NPT ports for vacuum supply and/or source.
-Available in two different colors : Black, Red.
Fittings include:
(qty 1) 1/4"NPT Hex Socket Plug (Brass)
(qty 2) 1/8"NPT Hex Socket Plug (Brass)
(qty 2) 1/8"NPT x 3/16" Hose Adaptor (Brass)
(qty 2) 1/8"NPT x 1/4" Hose Adaptor (Brass)
(qty 1) 1/4"NPT x 1/4" Hose Adaptor (Brass)
PART #: FID-EXT-30010 (FiD Evo 8/9 FiD Billet Aluminum Vacuum Manifold Kit)
PRICE: $59.95 + S/H
Billet Competition Fuel Rail
The FiD EVO 7-9 competition fuel rail allows additional fuel flow to support higher boost levels and ethanol fuels(E85/E98). The rail is designed to be used it conjunction w/ aftermarket fuel lines and pressure regulator.
Features:
-Designed to work w/ all factory style injectors.
-CNC machined from 6061 billet aluminum.
-8AN ORB inlet/outlet featuring ½" bore throughout.
-Mounts w/ supplied flush mounted cap screws which provides a clean smooth appearance.
-Anodized finish w/ engraved FiD logo.
-Available in three different colors : Black, Gold, Silver.
PART #: FID-FUE-30000 (FiD Evo 7-9 Competition Fuel Rail)
Billet Front Motor Mount
The FiD Evo 7-9 billet front motor mount is designed to stiffen and eliminate all the slop incorporated w/ the OEM factory mount and improve overall feel.
Features:
-CNC machined from billet 6061 aluminum
-Sleeve is machined of 1018 and zinc plated
-80A durometer insert bushings
-Anodized finish in gold
PART #: FID-EXT-30015 (FiD Evo 7-9 Billet Front Motor Mount)
PRICE: $89.95 + S/H
Billet EGR Blockoff Plate
The FiD Evo 7-9 EGR blockoff plate is designed for those who have eliminated emissions/EGR valve and looking for a clean look and solution to block off the vacuum ports incorporated w/ the EGR valve.
Features:
-Mounts w/ supplied flush mounted cap screws providing a clean smooth appearance.
PART #: FID-ENG-30000 (FiD Evo 7-9 EGR Blockoff Plate)
PRICE: $18.95 + S/H
Features:
Features:
Features:
Features:
Fittings include:
PRICE: $59.95 + S/H
Features:
Features:
PRICE: $89.95 + S/H
Features:
PRICE: $18.95 + S/H
https://www.evolutionm.net/forums/ev...lock-more.html
MrC
