Only the Best Here***Synapse Engineering BOV-DV-WG***
Vivid racing is now a proud direct dealer for Synapse Engineering.
Synapse has, dare I say the best BOV, DV, and Wastegates on the markets.
Pm me or call me 480.966.3040 x236 Dado directly to place an order!!!!!!
Here are the items they have to offer for the Evo's.
Synchronic DV Kit for Evolution 7, 8, 9 & X
Synchronic DV is the first, truly compact, zero-diaphragm, high-flow Diverter Valve with a blistering actuation time measured at 25 milliseconds. Mass air flow (MAF) and speed density (MAP) applications can apply the new design in push or pull orientation with the ability to fully re-circulate or vent-to-atmosphere the valve’s discharge. Construction is based on near-net investment casting of aerospace-grade Aluminum for the body, followed by post-process CNC machining of all components including the forged billet 6061 actuator assembly. A complete selection of available mounting flanges are interchangeable between the SB and DV series and users can either upgrade from an existing BOV/DV by simply bolting on an adapter or weld on to a new project using the Aluminum or Stainless weld flanges. Boost/vacuum connections are made via 1/8th NPT threaded bosses that accept either Boost Connect™ or included nickel-plated-brass barb fittings. Each assembly is pressure tested to withstand 60 psi and positive lock clamshell retainers are included with each assembly for fitment.
Synapse BOV Kit for Mitsubishi Evolution 7,8,9 & X
Black edition available too!!!!!
Synchronic BOV package – SB001 is the iconic Synchronic BOV that has set the standard for impossibly fast response from a BOV/DV. Completely modular, it can be installed as a vent-to-atmosphere BOV or re-circulating diverter valve. This universal package can be outfitted to most any application utilizing our interchangeable mounting flange system. By design, it is a pull-type valve only. This means that boost pressure keeps it closed, meaning no boost leaks upwards of 100+ psi of boost. It operates in a normally open condition. This means that it is designed to remain open under vacuum conditions. For maximum performance and reliability, it is recommended to install the Synchronic BOV in a re-circulated configuration with the discharge between the MAF sensor and turbocharger inlet.
The Synchronic BOV kit for Mitsubishi Evolution is a direct "Plug and Play" kit that can be installed in minutes. This kit comes complete with all components needed for install and is compatible with Evolution 8, 9, and X.
Very informative video:
Chris@nolimitmotors
447
Dec 26, 2018 04:09 PM
Synapse
89
Mar 28, 2009 08:00 PM
k3lv
16
Feb 18, 2008 09:35 PM
