In stock specials...Yes, I own. :)
Power Enterprise Super Strong Timing Belt
A must have for any modified engine
*Highly Increase Durability
*Slacklessness Prevents decreasing performance
*Camshaft keeps to be stable by decreased vibration [/color]
Only 139.99 Add a set of Fidanza cam gears for only 220.00
Power Enterprise 700cc Injectors
Only 409.99 Add a Walbro fuel pump for 90.00
Power Enterprse 210lph Fuel Pump kit
*JDM goodness
*Quieter running than standard upgrade pumps
*Direct PNP fitment
Only 199.99
Power Enterprse Air Impulse Intake
Only 139.99
Power Enterprse Boost gauge/Controller
*from -1 to 2.0 bar readout
*Electronic boost control
*Peak hold and warning
Only 399.99
Power Enterprise Fan switch controller
*Allows for monitoring of Water temp and oil tempo at push of a button
*Will control cooling fan turn on time
*Adjustable from inside the car
349.99 shipped
Just got my first shipment of these in and I cant wait to sell them to you all...
See why we think these are the best cam gears for your ride.
here
So what better way to do that then to have a sale on them.
225.00 shipped for a pair.
The number one name in high flow cats is here in Bolt-on mode for your EVO.
Random Technology uses only the best materials to produce their catalytic converters. Full stainless steel construction full stainless catalyst inside allowing for the highest flow while still being function.This is what high flow cats are made to do...Be efficient and flow better than stock.
Dont fall for the "alleged" High flow cats that use the same ceramic catalyst as the stock unit.These are not high flow cats, they are just less expensive universal replacements....This cat flows 598CFM's!!!!
The Random Tech is designed to fit with ANY exhaust and is available in 2.5 and 3" configurations...Pic is of one using a stock downpipe and TXS 3" cat-back...Enjoy
Only 249.99
good price
i am in the market soon to buy a timing belt and a walbro pump.. ummmm.
i am also in the process of looking and buying vishnus cam gears and a hks 264/272 cams. would a timing belt be necessary.. or whats the issue on that. ..
side note.. any xede users that use stage 1+ maps use third party hks cam gears, like Fidanza cam gears or HKS?.. or should i stay with vishnus.
Obsoleteasian : This timing belt Is a great upgrade, much stronger, less slack in the belt for more precise timing. The cam gfears are also a great choice. Fidanza produces the gears themselves and have over 20 years under their belt producing machined aluminum engine products. Check out this thread on some features of the cam gears.link
And with the extra money you save,It'll almost be like getting the fuel pump for free.
Edit: In fact, I am so confident you will be happy with the Fidanza gears, Ill give you the fuel pump for 60 bucks if you get the timing belt, and cam gears from me.
