Jdm Freaks Only!
Jdm Freaks Only!
The all new Espelir Exhausts from Japan have arrived and now available for your high performance tuner car. The exhausts are stainless steel, mandrel bent, straight through mufflers, include gaskets and silencer. The system is a complete bolt on and has a 3 year warranty from manufacturer defects. Vivid Racing is an authorized USA supplier for all your Espelir needs. The pipe diameter is 80mm with a 115mm tip. $532
A thorough lowering, 30mm to 70mm drop that is paired with a spring rate increase of 20% to 30%. This ACTIVE SUPER DOWN is the sports spring that makes your car look great with aftermarket wheels. The ride is kept comfortable - There is no other spring that can compare. Espelir EVO VIII ASD 03-UP Racing Springs Lower the car 20mm in the front and 20mm in the rear. $266
Check your info
You may want to confirm those front/rear drop numbers...I have the Active Super Down and the front end drops more than the rear. My car sits level or a little raked forward....wouldn't that mean the front drops lower than 20mm or at least more than the rear?
Here's a thread with a pic that clearly shows the front has dropped much more than the rear.
https://www.evolutionm.net/forums/sh...r&pagenumber=1
