Forge Wastegate Actuator + Invidia High Flow Housing Turbo Outlet EVO 8 COMBO DEAL!
Gold Sponsor
Forge Adjustable Silver Wastegate Actuator - EVO 8
Designed by Forge to replace the original component this updated actuator is serviceable and guaranteed for life. It comes with an updated diaphragm and a billet CNC machined aluminum mounting bracket.
The forge actuator can withstand higher amounts of boost when compared with the stock actuator.
Part # FMPACEV8
AND
Invidia EVO High Flow o2 Housing Turbo Outlet
The invidia o2 housing flows much better then the stock housing and most aftermarket housings. After installation you will notice a quicker turbo spool and more HP throughout the RPM band.
This o2 housing is approx. 2.9". The other o2 housings such as the megan racing, Authority, and DNP are only approx. 2.3"
Part # HS03ML8TOL
Price TOO LOW TO LIST! Please message us for SUPER LOW PRICE, this is a COMBO DEAL!
Make sure to check out even more EVO parts on Lancershop.com!
Part # FMPACEV8
AND
Part # HS03ML8TOL
bitterchild
Jun 11, 2013 09:18 AM
D-VO
Sep 6, 2012 08:17 AM
MrEvoVIII
Jul 18, 2010 09:23 AM
DSMEVO15
22
Mar 14, 2007 05:53 AM
