Blitz BOV kit for EVO!!!
Hello,
Got a shipment of Blitz DD BOV kit for the EVO.
Blitz DD BOV Kit
The purpose of the BLITZ® Blowoff Valve DD is to relieve compressor surge without reducing compressor speed. It controls boost pressure that is built up by the turbo and vents it into the atmosphere when the car is not under load (in between shifts). This prevents pressure from backing up into the compressor housing, causing the turbo impeller blade to rapidly stop or even worse, to spin backwards (compressor surge or backspin). Doing so can be potentially destructive to the turbine wheel and shaft. Repeated stress over time can cause eminent damage to the turbo charger and eventually lead to turbo failure. A blowoff valve is actuated by pressure changes only, ensuring quick valve responses and complete closures at idle. The BLITZ® blowoff valve not only improves performance and response, but also increases the life of the turbocharger.
* DD (Dual Drive) for maximum response (small port for low boost + larger port for high boost)
Please give me a call to order!
Price is $280 shipped!
Thanks
Cal
gruppe-s
510-498-8400
Blitz DD BOV Kit
Thanks
Cal
gruppe-s
510-498-8400
Gruppe-S
Vendor Classifieds
489
Dec 17, 2010 09:10 PM
Gruppe-S
346
Feb 10, 2010 10:20 AM
