Utec for U
Utec for U
$975 shipped!!! in stock!!!
proof that the Utec works, and you can't questions these numbers
These Utecs are so Kick ***, for all you who don't know here are some of it's functions:
*This thing is easy to install, you dont got to mess around with wires or anything just plug and play. the moment you open the box you will appreciate the fact that was made specifically for you evo.
*End-user programmable via PC,PDA with HyperTerminal. Fine tune the maps for your exact setup
*Pre-programmed base maps get you started quickly and safely. Base maps for our Staged upgrade packages, dyno proven and road tested. Maps can be e-mailed or simply downloaded then uploaded.
*5 maps plus “stock mode” selectable with a flick of the switch. Create custom maps for street gas, race gas, nitrous, or whatever. Optional remote swtich (no lap top required).
*Fuel, ignition timing, and boost are programmable in 250rpm increments up to 9000rpm over 10 load sites.
-Complete ignition timing control
-No need to worry about the factory ECU pulling timing anymore
-Be as aggressive or conservative as you want or just let the factory ECU
determine timing at any point in the map
-Fuel control
-Controlled via MAF sensor signal offset
-Tune stock and larger than stock injectors
-Load reference
-MAP (manifold pressure)
-Closed loop boost control programmable via Throttle Position and RPM
-No more re-adjusting the boost controller due to changes in temperature or
altitude
-Keeps boost low while in closed loop fuel mode for reliability
*Knock control, Automatically retards timing when the knock is detected and safeguarding against engine damage. Adjustable knock threshold, timing correction, and duration.
*On board data logging, Provides valuable information to assist you in tuning
*Built in programmable solenoid controller, Control nitrous, water injection, intercooler water spray or any other solenoid device.
*Drag racing launch control (secondary rev limit used during launch) Shave precious time off your launch!!!
*Free software upgrades, As we add more features, simply download the latest software version from our website and upload it to the UTEC.
Highly recommended by Vivid because of its combination of power, usability, ease of installation, and free software updates. It has proven to be very attractive for us enthusiast who want to extract the full potential of a tuned engine.
any questions or orders pm me, or call me at 1-866-44-vivid ext 226
jacky
-Fuel control
-Load reference
altitude
jacky
