THE BEST evo8 cams IN STOCK and READY to SHIP!!! $710 SHIPPED!!!
Hi guys,
we have ONLY 2 sets of Tomei Procam sets left in stock!!! $ Regular Price $810
SALE PRICE: $710 SHIPPED
If you are wondering why Tomei is better?
Tomei is one of the biggest engine part manufacturers in Japan.
What is so special about the Tomei Procams? Well, how about 260degrees of duration with 11.5mm lift!!!! On both teh intake and exhaust sides!!! The 260 duration ensures good idle, and the 11.5mm lift means MORE TORQUE that ANY OTHER CAM OUT THERE. EVen teh JUN cams have only 10.8mm lift. The Tomei Procam cam profile is asymetric, not symetric like the more common HKS cams.
We have been selling there sets like crazy. Tomei does not mass produce these, so do not expect to have many competitors with the same cams out there.
If you want the BEST, go Tomei - call us at 770-904-2644, and we will be glad to answer any questions that you might have.
George
George
Originally Posted by manOfaith
any dyno number 2 compare the hks's to the tomei cams? Such info would be very helpful since I don't think I have ever seen results of the tomei's.
Do the tomei's require valvesprings?
Thanx, Wayne
Thanx, Wayne
![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
Originally Posted by Bom's Evo
can stock valvetrain handle that lift??
any dyno numbers??
any dyno numbers??
How about a package deal with valvetrain?
Originally Posted by Guack007
No stock valve train can handle 11.5 mm lift (this is huge) Headwork is highly recomended.
Do you need cams/gears/springs/retainers? Or no gears?
George
Thanx, Wayne
Thanx, Wayne
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
Springs - yes, you need them
George
HKS Exhaust Camshaft (4G63BT) MITSUBISHI Lancer Evolution 2003> Cam Duration 264 Cam Lift (mm) 10.2
HKS Exhaust Camshaft (4G63BT) MITSUBISHI Lancer Evolution 2003> Cam Duration 272 Cam Lift (mm) 10.2
HKS Intake Camshaft (4G63BT) MITSUBISHI Lancer Evolution 2003> Cam Duration 264 Cam Lift (mm) 10.8
HKS Intake Camshaft (4G63BT) MITSUBISHI Lancer Evolution 2003> Cam Duration 272 Cam Lift (mm) 10.8
those are HKS specs , Do you guys plan to carry the new procams 270/270 11.5mm lift from Tomei ?
and for road race which would be a better choice ? 260/260 11.5mm or 270/270 11.5mm
Thanks GokuSSj4 I had no idea there where two sets of lift for 264's and 272"s with either a 10.2 or 10.8 This is the kinda things why I like being on EvoM.
Anyone know if the HKS 10.8 lift needs upgraded springs and retainers?
notice that both on the intake cams 264 or 272 have a 10.8mm lift, which tons of peeps have or are currently running on the stock valve springs with no problems.
Once you decide to pass the stock rev limiter on any or just about any application valve springs are highly recommended .
Edo Performance
17
Jun 21, 2007 12:21 PM
Boost Solutions
Jun 8, 2004 06:40 PM
