Go Fast Bits Stealth fx EVO Bovs In The Building
Gold Sponsor
Hey Guys
www.LancerShop.com has just received a pallet full of GFB Blow off valves from Australia. This blow off valve bolts on to your EVO in less then 10 minutes and is fully adjustable. We run this on one of our shop EVOs without any problems and it is LOUD!!
-Go Fast Bits Stealth FX EVO Blow Off Valve - $309.95
GFB Stealth FX Dual Port vents to the intake & vents to the atmosphere with its dual port action. This blow off valve is ideal if you want the loud swoosh without your car stalling out. By utilizing a unique air diverting system, you can control exactly how much air you dump to the atmosphere for noise, or the inlet for silence. By sending the vented air back to the inlet (rather than muffling it), there is no restriction and the valve still operates at maximum efficiency.
For cars with sensitive air flow meters such as the EVO, the valve can be tuned to vent just enough air back to the inlet to prevent backfiring while still giving the loudest possible blow-off noise. This BOV is fully adjustable by the flip of your wrist.
EVO Tech Tip: This is a 100% bolt on BOV for your 03+ EVO, no expensive flanges are required for installation.
order online at www.Lancershop.com or call us toll free 1-800-488-9174
Gold Sponsor
We also carry....
Go Fast Bits Whistle Trumpet: Simply screw this trumpet into any Stealth FX and it will produce an aggressive whistle that sets your car apart from others.
In normal driving conditions it gives a typical “whoosh” sound, but once the revs and boost level rise, a high pitch whistle noise takes over.
Gold Sponsor
leonard_shelby - Below is the sound clips for the GFB with & without the trumpet. Let me know if I can further assist you
http://www.gofastbits.com.au/index.p...stling_trumpet
i picked one of these up at the socal meet. OMFG!!! This is the most awsome thing ever. I run a 60/40 split with ZERO issues. This thing is a work of art and when it pops, EVERYONE looks!!! Get one!!! You will not be dissapointed. (Sorry Lancer shop, i didnt get it from you, but i plugged it for ya!!) RRR
