Mu Bforce Brakes $189 Full Coilover Kits $899 LOOK!!
We have 9 sets of bforce F&R pads combos for 189 shipped
Click to Order Note EVOM 189$ Shipped special price.
Also Running Sale on the Megan Coilovers $899 and the D2 Coilovers $950 While Supplies Last!!
D2 Coilovers
The RS coilover system is a 36 way dampner and rebound adjustable monotube full coilover system. The setup has seperate height and preload adjustments allowing for optimal adjustment and allowing full strut travel at all times along with pillowball upper mounts or top mounts. Mounts are constructed of 6061 powder coated aluminum. Aluminum valve body for extremely light weight construction.Threads are teflon coated to prevent rust. Rebuildable and serviceable in the US.
-36 way dampening adjustability
-3 degrees of camber adjustability
-3" inches of height adjustability
-Front and Rear pillowball mounts included
-Adjusting wrench included
-Default spring rate of 11k front & 9k rear
-Also can special order 8k front 6k rear.
Click to Order $950 Shipped!!
Megan Racing Coilover System
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
-Spring Rates: 8kg Front and 6kg Rear
-32 Levels of Adjustable Damper
-Pillow Ball Upper Mounts
-Rubber Dust Covers.
-Adjustable Ride Height
-Aggressive Spring Rates
-Single-Cyliner Design
-Aluminum Brackets
-32 Levels of Adjustmen
--1-8: Suggested for track use.
--9-16: Suggested for mountain/aggressive use.
--17-32: Suggested for common street use
-All coilover damper kits come with 1 year manufacture-defect warranty. - All Hardware is Included
Click To Order $899 Shipped!! SOLD OUT ETA 3-4 WEEKS!!
D2 Coilovers
-Aluminum Brackets
Originally Posted by walkedu
I'm still doing the research, but can you tell me which would be better for autoX purposes?
My buddy AutoX's with the D2's and loves them. Plus they have more adjustment.
Chris
Originally Posted by I'mStock
Any kind of deal if I order two sets of B-forces and some Megans?
Megans are out of stock ETA 3-4 Weeks now. $1300 Shipped for 2 F 2 R Bforce and set of D2's
Chris
I thought D2 'off the shelf' spring rates for the Evo were 8k front & 6k rear. Not the other way around.
Thats what I thought also but the REP I talked to said the other way around. Any way both are available for shipment just let me know which ones you would like.
Chris
