ONLY 1 set in Stock - Brembo 355 Front/Brembo 328 Rear
For our first post on EvolutionM, we are offering a set of Brembo Big Brake Kit at a killer deal. We have these in stock and are ready to ship.
Front - Brembo Gran Turismo Big Brake Kit
1999 - 2005 MITSUBISHI Mitsubishi Lancer Evo VI,VII,VIII
Retail - $3,295
Description - 355X32 2 Piece 4 Piston Calipers, Drilled Brake Rotors (RED)
OUR PRICE - $2,650 SHIPPED (OVER 20% OFF RETAIL)
Rear - Brembo Gran Turismo Big Brake Kit
Retail - $2,595
Description - 328X28 2 Piece 4 Piston Calipers, Drilled Brake Rotors (RED)
OUR PRICE - $2,100 SHIPPED (OVER 20% OFF RETAIL)
***$4,600 SHIPPED for BOTH FRONT AND REAR KITS***
The Gran Turismo system’s level of technology and performance is unrivaled by any other product on the market. These are the best brakes money can buy! Each system is designed vehicle specific for maximum performance and “Optimum Brake Balance”. Gran Turismo Systems are comprised of lightweight 4, 6 or 8 piston calipers and 1 piece or 2 piece “floating” vented rotors up to 15” in diameter. Calipers are available in red, silver or black and discs are available in cross drilled or slotted. The system also comes with brake pads, stainless steel brakelines and mounting hardware.
High Performance Friction Material:
Aggressive pads that provide the highest level of performance.
Cross-Drilled or Slotted Discs:
Clears gasses, cleans pads for better bite.
Mounting Brackets and Assembly Hardware:
Aircraft quality included and pre-torqued specifications.
Goodridge Stainless Steel Braided Brake Line:
DOT/TÜV approved.
Multi-Use Street, Performance Driving, Track Events Derived from Race-Based Components:
Increased stopping on the street, at drivers' schools and at club events with proven on-track performance at the highest levels of racing.
Floating Disc Mounting System with Billet Aluminum Hat:
Reduce Unsprung Weight for better handling and reduces heat-related stress; increases brake performance and pedal feel.
Four or Eight Piston Cast Aluminum Calipers:
Provide maximum braking force without the flex of sliding calipers.
Retail - $3,295
Retail - $2,595
DOT/TÜV approved.
That's actually not true.
The caliper is lighter, and stiffer.
More responsive, and has more precise control and modulation.
The piston sizes are actually slightly smaller.
The disc diameter is increased so the piston ares has to be reduced to provide optimum brake bias for the EVO.
The larger discs are 2pc. and fully floating.
The 2pc. design reduces unsprung weight.
It also minimizes heat transfer into the wheel bearing.
Everything about the aftermarket Brembo system is an improvement over stock.
When Brembo designs a system for an OEM application like the EVO, they have to take into considerations specific requirments from Mitsubishi as well as the fact that it may be a 19 year old kid in that car, as well as a 75 year old women.
When they design an aftermarket system, it is specifically designed for high performance use.
No one is better equiped to design an aftermarket brake system than the company who provided the OEM design. And since Brembo designed both, you have the confidence to know it was done correctly with every possible consideration for performance, function and safety taken into account.
Originally Posted by Derek888
Gary,
Regarding the big brake kit is there a reason why brembo went with the 4 piston caliper instead of a bigger 6 piston caliper?
The # of pistons within a caliper has very little to do with the capabilities of the caliper itself. The size of the pistons within the caliper is the main factor.
You can have a four, six or eight piston caliper, that all have the exact amount of piston area, and all three calipers can be used successfully in the same application.
When you say "instead of a bigger 6 piston caliper?" the answer would be that there is no reason to go "bigger".
If you had asked why not the correct 6 piston caliper instead of the correct 4 piston that we choose, then the answer would usually be related to wheel fitment, pad selection, caliper availability, and the many other reasons we always consider when choosing a caliper.
sweet!
once again demonstrating that the "vendors" who sell this stuff truly have no idea what they're selling, but don't have any problem handing out bad information to make a sale.
hey, better to just make up some crap off the top of your head than admit, "gosh, i actually haven't got the slightest idea how these differ from the stock calipers, because i know nothing about these brakes whatsoever!"
welcome to evoM, driven concepts. you'll fit right in.
and gary, thanks for the correction, but i hope you realize you're not going to make many friends around here.
I have compete knowledge of every part I sell here. The person that replied isn't the one that should be on this site posting, which I am sorry for. Any of our current items we have for sale in any of the vendors section I can give you any detailed information on. I do work in the office but was a mechanic for many years prior to working in the office. Any further posts will be given proper information before posting. The person, aka "problem" has been corrected. Thanks. As I side note, I will be covering the evo tuner shootout on behalf of Grassroots Motorsport Magazine, so if anyone from here will be there, come say hi.
Mellon Racing
EvoX 'For Sale' Suspension / Brakes / Handling
394
May 24, 2013 05:48 PM
CVR Motorsports
Evo 'For Sale' Suspension / Brakes / Handling
420
Sep 20, 2010 06:19 PM
evodave
Jun 9, 2010 02:29 PM
lutch
11
Jul 23, 2009 12:02 PM
