Swift/Whiteline/Cusco Staged Suspension Packages and KW Coilovers!!!
PLEASE CALL FOR SPECIAL PRICES!!!!
Stage 1 - $490 SHIPPED!
Best way to start your suspension!
Swift Springs
Whiteline Bumpsteer Kit
Whiteline 24mm rear adjustable swaybar
Stage 2 - $850 SHIPPED!
Includes all of Stage 1 PLUS
Whiteline Rear Trailing Arm Bushings
Cusco Rear Strut Brace
Cusco Version II Lower Brace
Stage 3 - $1320 SHIPPED!
Includes all of Stage 1 and 2 PLUS
Cusco Front Camber Plates
Whiteline Ball Joint Extenders
Whiteline Steering Precision Kit
all shipping prices are to the 48 continental US states.
- Andrew
Swift Springs
- Andrew
Swift Springs -- $276.75 shipped
EVO 8 and 9
269lbs/inch front
319lbs/inch rear
EVO MR
269lbs/inch front
314lbs/inch rear
Drop for both
35mm front
20mm rear
Call to order!
410-579-1501
Whiteline Ball Joint Extenders - $185 shipped
Whiteline Bumpsteer Correction Kit - $60 shipped
Whiteline Trailing Arm Bushings - $90 shipped
EVO 8 and 9
269lbs/inch front
319lbs/inch rear
EVO MR
269lbs/inch front
314lbs/inch rear
Drop for both
35mm front
20mm rear
Call to order!
410-579-1501
KW Variant 3
Race technology for the road with adjustable compression and rebound damping
Avaliable for EVO 8 and 9
$1899 shipped for coilovers only!!!
$2300 shipped for Cusco Front Camber Plates and Rear Pillowballs!!!
The new Variant 3 is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the highspeed set-up, so decisive for driving comfort, has been preset by our engineers.
• Independently adjustable damping technology -rebound and compression damping
• inox-line stainless steel technology at no extra charge
• Individual height adjustment
• German TUEV-tested adjustment parameters
• High-quality components for long life
• Comprehensive documentation for ease of use
• Infinitely adjustable rebound damping
• 14- level adjustable compression damping
• Unique, independently functioning damping power adjustment
•Spring rate of 9/6
CALL FOR ADDITIONAL SPRING RATES!!!
http://gtworx.com/catalog/product_in...oducts_id=1178
Performance Friction 2 piece dimpled rotors
- Special machining process assures the lowest possible runout and thickness variation.
- Patented slot design gives much higher brake bite.
- Exclusive high temperature metal alloy resists hot spots and shrugs off the highest heat loading.
- Computer designed vanes maximize cooling air flow and prevent thermal distortion.
Race proven in nearly every major motorsports venue around the world.
Special introductory price of $629 SHIPPED for front pair of rotors + hats.
http://gtworx.com/catalog/product_in...oducts_id=1184
Performance Friction Brake Pads
- Exclusive Multi-Layer Technology ™ isolates, dampens, and eliminates noise.
- Vehicle specific formulation for exceptional stopping power over a longer performance life.
- Patented Ionic Fusion™ friction bonding technology for the strongest bond to the backing plate.
- Statistically controlled quality steel plates ensure proper fit with every pad.
- Patented Powder Coating prevents corrosion and extends caliper life.
- NO Asbestos, NO Lead, NO Cadmium, NO Chromium, NO Potassium Titanate, NO Fillers - Environmentally Friendly.
- Meets or EXCEEDS OE and FMVSS Safety Standards.
PFC-11 street pads
Front $115 shipped
http://gtworx.com/catalog/product_in...oducts_id=1187
PFC-97 Street/Track pads
Front $260 shipped
http://gtworx.com/catalog/product_in...oducts_id=1185
Rear $165 shipped
http://gtworx.com/catalog/product_in...oducts_id=1186
Ohlins Sportline Coilovers
560lb/in Front, 450lb/in Rear main springs
-25 clicks of rebound adjustment
-Adjustable front camber plates
-Pillowball rear mounts
-Inverted front strut design
-Includes helper springs
-Includes main springs
$2499 Shipped!!!
Ohlins Fixed-Perch Struts
-Uses OEM style springs
$1799 Shipped!!!
$1999 Shipped with Swift Springs!!!
Instructions can be found here: http://www.globalperformanceparts.co...ons/KCA390.pdf
It's not too bad. 1 hour-ish of work, usually less. Just got to get up in there near the steering mounts. Can be done much quicker.
- Andrew
- Andrew
Grrrr....trust me i know. That was not fun, especially since the Prodrive ones i had were out of spec and didn't fit......so after 2-3 hours of trying to wedge the drivers side one in or trying to trim it, i ended up putting the stock one back in on that side.
I should have gone with Whiteline.
- Andrew
- Andrew
You should have been here today when we got in our huge shipment of Racecomp Engineering Tarmac II coilovers made by KW for Subaru STi. Very pretty. Blue and black instead of the standard KW yellow and purple.
Horrible photos of me assembling like 10 of them with custom springs, setting them up and making adjustments will not be posted. I need to shave.
And now they are all gone
- Andrew
- Andrew
