Suspension/Brake Packages:SWIFT/STOPTECH, ENDLESS/FERODOS/WHITELINE WHOLESALE DIRECT!
New Pricing from Stoptech!!!
Stoptech Slotted Rotors for EVO!
Front pair - $225 shipped!
Rear pair - $185 shipped!
Front and Rear complete set of 4 slotted rotors - $390 shipped!!
STOPTECH Stainless Steel Brakelines!! DOT APPROVED!
StopTech stainless steel brake lines improve pedal feel and reduce the amount of time between applied pedal pressure and actual deceleration by reducing the expansion that is allowed by stock rubber flex lines. This provides a quicker pedal response and allows the driver to maintain consistent brake pressure and precision brake modulation.
MSRP $166, Now on sale: $155 Free Shipping!!
STOPTECH Stage 2 Kit
StopTech Stage 2 Slotted Brake Kit Mitsubishi Lancer EVO 7 & 8 (Axxis ULT pads). The kit includes StopTech stainless steel (DOT compliant) front and rear brake lines, three (3x) 500mL bottles of Motul RBF600 (Synthetic DOT 4) brake fluid StopTech SportStop slotted front and rear stock replacement rotors.Axxis ULT front and rear high performance street brake pads. ONLY $769 FREE SHIPPING!
Brake Pads for Stock Calipers
Ferodo DS2500 Brake Pads are now back in stock!! Front and rear COMBO $275 shipped!!!
DS2500 Front pads - $190 shipped!!
DS2500 Rear Pads - $99 shipped!!
Front and rear Combo Pak - $275!!! shipped!!!
HAWK HP-Plus Front Pads - $145 shipped!
HAWK HP-Plus Rear Pads - $85 shipped!
HAWK HP-Plus Front and Rear Complete Set - $220 Shipped!
Motul RBF600 Brake Fluid - $15 per bottle! Free Shipping!
We have plenty of ENDLESS Brake Pads in STOCK as well!!!
Endless CC-APads are very comparable to the Ferodo DS2500s.
- No noise/low dust
- high friction 0.50
- Decent MOT of 900 degrees
- Non corrosive dust, cleans easy
- Great street/occasional track/spirited driving
$152 each set! FREE SHIPPING!
Complete Front and Rear Endless CC-A Pads - $300 Free shipping!
Endless Vita Nuova
Vita Nuova is a most popular, entry level compound for the everyday sports-minded, city driver concerned for safety.
- very low dust/low noise
- coefficient of friction - 0.3 - 0.35
- Decent MOT of 570 degrees for city street type of driving
- non corrosive dust, clean easy
$95 each set! FREE SHIPPING!
Complete Front and Rear Endless Vita Nuova Pads - $179 Free shipping!
Whiteline Suspension Bushing Kit
These Whiteline suspension bushing kit replace your mushy or worn out suspension bushings and improves the overall chassis dynamics of your evo. A true must have for you avid auto-x racers and track warriors!
The complete kit is listed below,
*1) W0588 Whiteline Rear Toe-Control Arm Inner Bushings - 03+ EVO, MSRP $31.49 Our Price: $29
*2) W0589 Whiteline Rear Lower Control Arm Shock Bushings - 03+ EVO, MSRP $39.79 Our Price: $37
*3) W0590 Whiteline Rear Control Arm Front Bushings - 03+ EVO, MSRP $147.77 Our Price: $140
*4) W0591 Whiteline Rear Control Arm Rear Bushings - 03+ EVO, MSRP $40.81 Our Price: $38
*5) W0592 Whiteline Differential to Chassis Bushings - 03+ EVO MSRP $85.37 Our Price: $80
*6) W0593 Whiteline Front Control Arm Bushings - 03+ EVO, MSRP $77.40 Our Price: $73
*7) W0594 Whiteline Rear trailing arm lower (front) - 03+ EVO, MSRP $87.01 Our Price $82
*8) KCA388 Whiteline Rear Bump steer kit - 03+ EVO, MSRP $56.52 Our Price: $53
*9) KCA390 Whiteline Front Steering precision kit - LHD 03+ EVO, MSRP $60.27 Our Price: $57
Complete Whiteline Bushing Kit - MSRP: $626.43, EVOLUTIONM Member Pricing: $545 Free shipping!
Pricing is for 48 continental states! Alaska, Hawaii, and PR will need additional to ship. Please give us a call for best rate quote!
Thank you!
Calvin
- No noise/low dust
Endless Vita Nuova
Thank you!
Calvin
Whiteline Roll Center Adjusting Kits are now available thru Speed Element!!
KCA395 roll centre adjuster kit suits ALL left and right hand drive EVO 7-8-9. The kit contains 2x specially engineered ball joints and custom steering tie-rod ends designed to lower the front roll centre with out affecting the steering geometry. Unlike KCA396 which was designed only for right hand drive and used a series of special spacers, KCA395 will work on both left and right hand drive and is much faster and easier to fit.
How it works:
The KCA395 is designed to raise the front roll-centre geometry by using new specially engineered ball-joints and tie-rod ends while still maintaining original steering geometry. Suitable for both and left & right hand drive vehicles.
The EVO front roll geometry actually encourages roll the lower you go. Tests on the Project EVO showed that raising the front roll-centre resulted in a substantial increase to front roll resistance and a significant reduction in suspension compression of the outside frotn wheel during cornering (less roll).
This improves weight distribution, maintains a better camber angle and ultimately improves front grip. The overall outcome is significantly reduced understeer through reduced front wheel compression, as well as improved steering feel, steering precision and vehicle stability.
Fitting KCA395 is a must for lowered vehicle but can also be used on standard vehicles. Is also designed to be sued together with and complementary to KCA387 (EDM or JDM) or KCA388 (USDM) steering precision kit
Kit is supplied with 2x complete sets of specially modified ball-joints, steering tie rod ends, grease cups, mounting hardware and comprehensive fitting instructions.
This is the same kit successfully used and tested in Martin Notaras' Whiteline Project EVO 8 and MRT's EVO 9 development car. Retail price will be $182.00.
EVOM members, AutoXer and Road Racers, Please PM me for special introductory offer!!
Ingall Engine Torque Dampers are now back in stock at Speed Element!
A self-contained elastomeric shock that mounts on brackets between the engine and the chassis. It reduces extreme engine movement and dampens the motion, providing many benefits:
- Greatly improved off-the-line acceleration
- Smoother shifting
- Reduced wear on exhaust system joints
- Less vibration transmission to the driver compared to polyurethane motor mounts.
- Less shock load, compared to torque straps and chains.
- Drifting – helps reduce shock loads when wheels gain traction.
- Reduced wheel hop
- Improved vehicle stability
- Reduced shock loads on driveline components
- Reduces motor movement – decreases the chance of motor parts rubbing against the hood and frame.
Fits: Mitsubishi Lancer Evolution VIII and Lancer Evolution IX
Speed Element Special Clearance Price- $145 shipped!!!! (EXPRESS SHIPPING 2-3 Days for FREE!)
Got 3 sets left!!
Please Hurry!
Thank you!
Calvin
How it works:
- Smoother shifting
- Reduced wheel hop
Got 3 sets left!!
Please Hurry!
Thank you!
Calvin
Spun Autosports
Evo 'For Sale' Suspension / Brakes / Handling
119
Aug 23, 2011 04:42 AM
Spun Autosports
Jan 17, 2011 04:33 PM
CVR Motorsports
420
Sep 20, 2010 06:19 PM
Speed Element
Mar 10, 2008 11:42 AM
Speed Element
13
Nov 27, 2006 11:54 PM
