ROBISPEC Swaybars
ROBISPEC Swaybars
Finally!
Front 2 position adjustable = to 23mm or 26mm front bar $250.00
Rear 4 position adjustable = to 23.5 to 27.5mm rear bar $240.00
this gives you up to 8 different swaybar settings to get your car just right for each track you work on.....depending on tire/grip avalible on each given day.....
As used on the last redline time attack to win street and modified classes (yes different swaybar settings for different grip tires.....)
What do you suggest for a recently JIC FLT-A2 IX RS that had a RobiSPEC corner-weight/align w/ rear bump-steer kit on stock F&R sway bars with factory Advans? For the most neutral feeling, (prefer tiny oversteer vs. understeer.) What do you suggest for front and rear sizes?
are those prices shipped?
what's run is a stock front(24mm) and 25mm rear untill you get to around 400 whp and big sticky tires.....then we go to a 26mm front and 27mm rear (26-28mm range)
I brought these out to give the most flexability .....run both bars soft and they are neutral with street rubber as you go wider and softer you add bar stiffness to compensate....
Finally!
On the rear bar, how would the 4 settings compare in stiffness to the 3 that are available on a 25mm Hotchkis hollow rear bar?
Thanks!
Solid forged ends 24.5 nominal diameter front and Rear
Also have lower arm multi point attachments for even MORE adjustability!
order through Paypal
evo4fun@gmail.com
evo4fun@gmail.com
