Evo 'For Sale' Suspension / Brakes / Handling Includes pads, rotors, springs, shocks, swaybars, and other handling related components.
GTWorx EVO Springs are IN STOCK NOW!!! Oh and coilovers from KW and Ohlins.....
Old Aug 22, 2007, 08:52 AM
GTWORX.com's Avatar
GTWorx Street/Track Springs
The long awaited "mild drop" high performance spring for your Mitsubishi Evolution.
Developed with direct feedback from EVO owners, the GTWorx Springs are an innovative new product that is unlike anything currently available on the market. Rather then just copying other's rates, we allowed the end user to have a say in the final product, and we are very excited to offer a completely new line of thinking in the aftermarket spring arena.
Introducing the GTWorx Street/Track Springs, an OEM replacement spring for 2003-2007 Mitsubishi Lancer Evolution 8 and 9, and the next in Racecomp Engineering's growing line of performance springs for Subaru Impreza, Subaru Legacy, and Mitsubishi Evolution. Designed for use with standard Mitsubishi EVO dampers, EVO MR Bilsteins, or Ohlins Fixed Perch Replacement Struts, these springs are intended for both the daily driven street driver as well as the autocross and track day weekend warrior.
Having a much more subtle/mild drop in comparison to most aftermarket springs, these are perfect for EVO owners not looking for a ride height much lower then stock, and yet are still looking for spring rates that are tailored to the track and auto-x course. Matched perfectly with both the dampers, these maintain great ride quality while delivering performance on par with many coilover systems!
Follow the development of the springs in this thread:
https://www.evolutionm.net/forums/sh...=217693&page=2
Spring rates:
10% stiffer then Swift Springs
Drop:
20mm front
15mm rear
GTWorx/Racecomp Engineering Street/Track Springs - $275 shipped!!!
Please call 410-579-1501 to order!
These are in stock NOW!!!
GTWORX.com is offline
GTWORX.com's Avatar
Suspension Packages:
Stage 1 - $499 SHIPPED!
Best way to start your suspension!
GTWorx Springs
Whiteline Bumpsteer Kit
Whiteline 24mm rear adjustable swaybar
Stage 2 - $759 SHIPPED!
Includes all of Stage 1 PLUS
Whiteline Rear Trailing Arm Bushings
Whiteline Roll Center Kit/Ball Joint Extenders
Old Aug 22, 2007, 08:53 AM
GTWORX.com's Avatar
Swift Springs -- $276.75 shipped
Whiteline Roll Center Correction Kit/Ball Joint Extenders - $175 shipped
Whiteline Bumpsteer Correction Kit - $60 shipped
Whiteline Trailing Arm Bushings - $90 shipped
Old Aug 22, 2007, 08:54 AM
GTWORX.com's Avatar
Ohlins DFV Sportline Coilovers
Just Released!!!
450lb/in Front, 560lb/in Rear main springs
25 clicks of rebound adjustment
Adjustable front camber plates
Pillowball rear mounts
Inverted front strut design
Includes Eibach main springs
Ride Height adjustment seperate from preload
$2649 Shipped!!! Custom Rates Available!!!
Ohlins Fixed-Perch Struts
Uses OEM style springs
Ultimate Ride Quality
$1799 Shipped!!!
$1999 Shipped with GTWorx or Swift Springs!!!
Old Aug 22, 2007, 08:55 AM
GTWORX.com's Avatar
Dave Mac KW Variant 3 Auto-x Coilovers
Wanna win your next autocross? These will help.
$2049 shipped for custom rate and tuned coilovers!!!
We worked extensively with Dave Mac this season to develop these custom KW Variant 3 coilovers. A variety of ride heights, alignment settings, and damper settings were tested throughout the year until we found the ultimate STU autocross set-up. Countless autocross wins and podiums later, we can now offer the Dave Mac KW Autocross Special!!!
• Independently adjustable rebound and compression damping
• inox-line stainless steel technology, rust PROOF.
• Individual height adjustment
• German TUEV-tested adjustment parameters
• High-quality components for long life
• Comprehensive documentation for ease of use
• Infinitely adjustable rebound damping
• 14- level adjustable compression damping
ALL Set-up instructions included.
Please call if you have any questions or would like to order!
410-579-1501
Old Aug 22, 2007, 08:57 AM
GTWORX.com's Avatar
Perrin 25mm Rear Adjustable Sway Bar - $240 shipped
Includes stout mounts.
Old Aug 23, 2007, 08:09 AM
GTWORX.com's Avatar
bump.
Old Aug 24, 2007, 08:03 AM
GTWORX.com's Avatar
tops....GTWorx springs in stock!
Old Aug 27, 2007, 07:23 PM
GTWORX.com's Avatar
late night bump
Old Aug 28, 2007, 05:33 AM
SwabeLife's Avatar
is that the actual pics of the ohlins dfv for evo?
SwabeLife is offline
Old Aug 28, 2007, 07:26 AM
GTWORX.com's Avatar
actually, that's the older PCV version.....i didn't catch that. changing it today.
The DFV's don't need the helper spring since they are dual height adjustable. That's the only difference in terms of looks.
- Andrew
Old Aug 28, 2007, 08:15 AM
GTWORX.com's Avatar
fixed it.
Old Aug 29, 2007, 11:06 AM
GTWORX.com's Avatar
bumps
Old Aug 30, 2007, 09:14 AM
GTWORX.com's Avatar
still got some in stock!
Old Sep 4, 2007, 08:08 AM
GTWORX.com's Avatar
bump!
Quick Reply: GTWorx EVO Springs are IN STOCK NOW!!! Oh and coilovers from KW and Ohlins.....
