SWIFT/STOPTECH/Whiteline/Megan/KW/HAWK Suspension Brake Packages!
#36
SWIFT Sport Mach Springs!!!!
MSRP: $369 + Shipping!
Speed Element Special Offer PLEASE PM FOR BEST PRICING!! FREE SHIPPING!!!
SWIFT Springs have just released for the Spec-R Sport Springs for the U.S Market!!!
Sport Springs SPEC-R
For motorsports minded individual with a passion in winning.
SWIFT made Sport Springs Spec-R is made for true track racing enthusiasts that wants to take their vehicle to the next level.
Sport Springs Spec-R is engineered with 2 main characteristics.
1) Redesign lowering ride height to maximize the suspension performance allowing the vehicle to fully absorb road condition for maximum traction.
2) Increase in spring rate to further enhance cornering speed through entry & exit. The increase in spring rate is based on the vehicle factory stock valving settings. Sport Springs Spec-R is increase to the optimal rate that the stock shocks can handle. Higher performance shocks are not required, but recommended.
The Spec R springs are wound with the same engineering as their sports springs. With the exception of stiffer rates and slight change in ride height; you can expect the same characteristics as their sports springs.
Applications: 03+ EVO GSR and MR specs
RS/GSR - Front Spring Rates: 3.2 - 4.8 kg/mm (179 - 269 lbs/inch), Rear Spring Rates: 3.7 - 5.7 kg/mm (207 - 319 lbs/inch)
RS/GSR Ride Height Drop: 1.4" Front and 0.8" Rear
MR - Front Spring Rates: 3.2 - 4.8 kg/mm (179 - 269 lbs/inch), Rear Spring Rates: 2.8 - 5.6 kg/mm (157 - 314 lbs/inch)
MR Ride Height Drop: 1.4" Front and 0.8" Rear
MSRP: $389, Speed Element Introductory Offer: PLEASE PM FOR BEST PRICING!!! FREE SHIPPING!!.
Whiteline Suspension Bushing Kit
These Whiteline suspension bushing kit replace your mushy or worn out suspension bushings and improves the overall chassis dynamics of your evo. A true must have for you avid auto-x racers and track warriors!
The complete kit is listed below,
*1) W0588 Whiteline Rear Toe-Control Arm Inner Bushings - 03+ EVO, MSRP $34.48 Our Price: PM FOR PRICING
*2) W0589 Whiteline Rear Lower Control Arm Shock Bushings - 03+ EVO, MSRP $43.68 Our Price: PM FOR PRICING
*3) W0590 Whiteline Rear Control Arm Front Bushings - 03+ EVO, MSRP $162.15 Our Price: PM FOR PRICING
*4) W0591 Whiteline Rear Control Arm Rear Bushings - 03+ EVO, MSRP $44.78 Our Price: PM FOR PRICING
*5) W0592 Whiteline Differential to Chassis Bushings - 03+ EVO MSRP $93.69 Our Price: PM FOR PRICING
*6) W0593 Whiteline Front Control Arm Bushings - 03+ EVO, MSRP $84.93 Our Price: PM FOR PRICING
*7) W0594 Whiteline Rear trailing arm lower (front) - 03+ EVO, MSRP $95.50 Our Price PM FOR PRICING
*8) KCA388 Whiteline Rear Bump steer kit - 03+ EVO, MSRP $62.46 Our Price: PM FOR PRICING
*9) KCA390 Whiteline Front Steering precision kit - LHD 03+ EVO, MSRP $66.92 Our Price: PM FOR PRICING
Complete Whiteline Bushing Kit - MSRP: $688.59, EVOLUTIONM Member Pricing: $555 Free shipping!
Whiteline Roll Center Adjusting Kits are now available thru Speed Element!!
KCA395 roll centre adjuster kit suits ALL left and right hand drive EVO 7-8-9. The kit contains 2x specially engineered ball joints and custom steering tie-rod ends designed to lower the front roll centre with out affecting the steering geometry. Unlike KCA396 which was designed only for right hand drive and used a series of special spacers, KCA395 will work on both left and right hand drive and is much faster and easier to fit.
How it works:
The KCA395 is designed to raise the front roll-centre geometry by using new specially engineered ball-joints and tie-rod ends while still maintaining original steering geometry. Suitable for both and left & right hand drive vehicles.
The EVO front roll geometry actually encourages roll the lower you go. Tests on the Project EVO showed that raising the front roll-centre resulted in a substantial increase to front roll resistance and a significant reduction in suspension compression of the outside frotn wheel during cornering (less roll).
This improves weight distribution, maintains a better camber angle and ultimately improves front grip. The overall outcome is significantly reduced understeer through reduced front wheel compression, as well as improved steering feel, steering precision and vehicle stability.
Fitting KCA395 is a must for lowered vehicle but can also be used on standard vehicles. Is also designed to be sued together with and complementary to KCA387 (EDM or JDM) or KCA388 (USDM) steering precision kit
Kit is supplied with 2x complete sets of specially modified ball-joints, steering tie rod ends, grease cups, mounting hardware and comprehensive fitting instructions.
This is the same kit successfully used and tested in Martin Notaras' Whiteline Project EVO 8 and MRT's EVO 9 development car. Retail price will be $196.47
EVOM members, AutoXer and Road Racers, Please PM me for special X-Mas offer!!
Pricing is for 48 continental states! Alaska, Hawaii, and PR will need additional $ to ship. Please give us a call for shipping rate quote!
Please take a look!
The package consists of the following:
*Whiteline 24mm 3-way Adj. Rear Swaybar - MSRP: $193.37 - PM FOR PRICING
*Whiteline Rear bump steer correction kit - MSRP: $62.46 - PM FOR PRICING
*Whiteline Front roll center adjusting kit - MSRP: $196.47 - PM FOR PRICING
***Speed Element Summer Track Package - PM FOR PRICING Free Shipping!!!!***
STOPTECH Brake Components and Packages
Stoptech Slotted Rotors for EVO!
Front pair - $299 shipped!
Rear pair - SOLD OUT shipped!
Front and Rear complete set of 4 slotted rotors - SOLD OUT FREE SHIPPING!!!
Shipping to Hawaii, Alaska, Puerto Rico and Virgin Islands will be extra!
STOPTECH Stage 2 Kit w/ Hawk HPS Brake Pads
Thi Staged kit includes StopTech stainless steel (DOT compliant) front and rear brake lines, three (3x) 500mL bottles of Motul RBF600 (Synthetic DOT 4) brake fluid StopTech SportStop slotted front and rear stock replacement rotors. Hawk HPS front and rear high performance street brake pads. ONLY $849 FREE SHIPPING!
STOPTECH Stage 2 Kit w/ Project Mu B-Force
This Staged kit includes StopTech stainless steel (DOT compliant) front and rear brake lines, three (3x) 500mL bottles of Motul RBF600 (Synthetic DOT 4) brake fluid StopTech SportStop slotted front and rear stock replacement rotors. Project Mu B-Force front and rear high performance street brake pads. ONLY $899 FREE SHIPPING!
STOPTECH Stage 2 Kit w/ Ferodo DS2500s
This Staged kit includes StopTech stainless steel (DOT compliant) front and rear brake lines, three (3x) 500mL bottles of Motul RBF600 (Synthetic DOT 4) brake fluid StopTech SportStop slotted front and rear stock replacement rotors. Ferodo DS2500s front and rear high performance street brake pads. ONLY $949 FREE SHIPPING!
STOPTECH Stainless Steel Brakelines!! DOT APPROVED!
StopTech stainless steel brake lines improve pedal feel and reduce the amount of time between applied pedal pressure and actual deceleration by reducing the expansion that is allowed by stock rubber flex lines. This provides a quicker pedal response and allows the driver to maintain consistent brake pressure and precision brake modulation.
MSRP $207.50, Now on sale: $185 Free Shipping!!
Brake Pads for Stock Calipers
Ferodo DS2500s and Hawk HP-Plus and HPS Brake Pads are now Back In STOCK!! FREE SHIPPING!!
DS2500 Front pads - $190 shipped!!
DS2500 Rear Pads - $99 shipped!!
Front and rear Combo Pak - $295!!! shipped!!!
Motul RBF600 Brake Fluid - $15 per bottle! + shipping.
How it works:
Please take a look!
#38
STOPTECH 332 x 32mm FRONT Big Brake Kit
STOPTECH Mitsubishi Lancer Evolution 8 & 9 Big Front Brake kit , 2 piece 332x32mm floating directional rotors, drilled or slotted, 7075 T-6 billet Aluminum hats with anti-rattle hardware, 4 piston calipers black or red, Axxis Ultimate pads, stainless steel front brake lines, fits factory 17" wheels. Add $100 per pair for drilled rotors.
MSRP: $2195, Now on Sale: $1975 + Tax.
STOPTECH 355 x 32mm FRONT Big Brake Kit
STOPTECH Mitsubishi Lancer Evolution 8 & 9 Big Front Brake kit , 2 piece 355x32mm floating directional rotors, drilled or slotted, 7075 T-6 billet Aluminum hats with anti-rattle hardware, 4 piston calipers black or red, Axxis Ultimate pads, stainless steel front brake lines, 18" wheels is required. Add $100 per pair for drilled rotors.
MSRP: $2595, Now on Sale: $2335 + Tax.
[size=12pt]STOPTECH 355 x 32mm w/ 6 Piston Caliper Big Brake Kit [/size]
STOPTECH Mitsubishi Lancer Evolution 8 & 9 Big Front Brake kit , 2 piece 355x32mm floating directional rotors, drilled or slotted, 7075 T-6 billet Aluminum hats with anti-rattle hardware, 6 piston calipers black or red, Axxis Ultimate pads, stainless steel front brake lines, 18" wheels is required. Add $100 per pair for drilled rotors.
MSRP: $2995, Now on Sale: $2695 + Tax.
STOPTECH 328x 28mm REAR Big Brake Kit
STOPTECH Mitsubishi Lancer Evolution 8 & 9 Big Front Brake kit , 2 piece 328x28mm floating directional rotors, drilled or slotted, 7075 T-6 billet Aluminum hats with anti-rattle hardware, 2 piston calipers black or red, Axxis Ultimate pads, stainless steel front brake lines, fits factory 17" wheels. Add $100 per pair for drilled rotors.
MSRP: $2295, Now on Sale: $2065 + Tax.
Options:
Standard Color Calipers choice: Red or Black.
Custom Color Caliper Choice: Additional $200 each Caliper.
#39
****hey guys,
Due to the merger between the Stoptech/Centric and Power Slot Rotor company, Stoptech/Centric will be using the Power Slot rotor's inventory as their own and there will be a slight price increase due to this.
Please PM me for best pricing!
Thank you****
Thank you****
