Evo 8 & 9 - Voxa D.O.T. Stainless Steel Brake Line Kits
To order, call...
(888) 591-6277 and mention this thread to receive the discount.
Nukabe is proud to introduce a new line of braking components called VOXA. These VOXA stainless steel brake lines are available in two colors (red or blue).
VOXA's stainless steel brake lines offer a SUPERIOR DESIGN, with a 5-layer system that passes the difficult D.O.T. "whip test". The multi-layer brake line is designed to eliminate brake line expansion while preventing sand and grit from getting under the stainless braid. This protection also helps prevent corrosion build up, which increases the longevity of your brake lines.
Benefits:
1. The hose is constructed from 5 layers of material, as opposed to the 2 layers in most stainless steel brake lines.
2. The first layer is Teflon, then a Kevlar braid. A black anti-chafe coating separates the Kevlar from the stainless steel braid and prevents them from abrading each other
3. The final layer is a colored vinyl heat shrink wrap. This gives a distinct look, as well as preventing sand and grit from getting underneath the stainless braid.
4. The fittings are a one-piece design, and are permanently crimped onto the hose system. The combination of the fitting and the hose design allow the completed brake lines to pass the difficult D.O.T. “whip test” with ease! Many stainless steel brake lines on the market do not have these unique features, and most do not have the D.O.T. certification.
Retail: $169.00/set
Sale: $129.00/set shipped*
Each kit includes front and rear pair of lines with line locators and crush washers. Please specify Evolution 8 or Evolution 9 when ordering. Price is the same for either car.
**free shipping is only for the lower 48 states via UPS ground**
To order, call...
Benefits:
Retail: $169.00/set
To order, call...
