SWIFT Sport Mach Springs and Spec-R Springs
SWIFT Sport Mach Springs!!!!
MSRP: $369 + Shipping!
Speed Element Special Offer $276.75 Free Shipping!!!
SWIFT Springs have just released for the Spec-R Sport Springs for the U.S Market!!!
Sport Springs SPEC-R
For motorsports minded individual with a passion in winning.
SWIFT made Sport Springs Spec-R is made for true track racing enthusiasts that wants to take their vehicle to the next level.
Sport Springs Spec-R is engineered with 2 main characteristics.
1) Redesign lowering ride height to maximize the suspension performance allowing the vehicle to fully absorb road condition for maximum traction.
2) Increase in spring rate to further enhance cornering speed through entry & exit. The increase in spring rate is based on the vehicle factory stock valving settings. Sport Springs Spec-R is increase to the optimal rate that the stock shocks can handle. Higher performance shocks are not required, but recommended.
The Spec R springs are wound with the same engineering as their sports springs. With the exception of stiffer rates and slight change in ride height; you can expect the same characteristics as their sports springs.
Applications: 03+ EVO GSR and MR specs
RS/GSR - Front Spring Rates: 3.2 - 4.8 kg/mm (179 - 269 lbs/inch), Rear Spring Rates: 3.7 - 5.7 kg/mm (207 - 319 lbs/inch)
RS/GSR Ride Height Drop: 1.4" Front and 0.8" Rear
MR - Front Spring Rates: 3.2 - 4.8 kg/mm (179 - 269 lbs/inch), Rear Spring Rates: 2.8 - 5.6 kg/mm (157 - 314 lbs/inch)
MR Ride Height Drop: 1.4" Front and 0.8" Rear
MSRP: $369, Speed Element Introductory Offer: $276.75 Free Shipping!!!
Or $399 Installed OTD!
Advantage of going with S.W.I.F.T Springs
http://www.swiftsprings.com/advantage.html
More info added:
The spec-Rs are Progressive rated coil springs.
The initial spring rates on the coils are the same as the regular sport machs springs but the difference is, as the coils of spec-R springs are compressed during high speed and hard cornering, it'd essentially progressed to harsher ride compare to regular sport machs.
As you can see, the range of progression on spec-r springs are also wider in their data/spec sheets.
SWIFT Spec-R
To place an order, please either give us a call (510-226-8822) or simply submit paypal payment to our paypal: Sales@speedelement.com
Thank you
Speed Element
More info added:
SWIFT Spec-R
Thank you
Speed Element
Justin at STM
EvoX 'For Sale' Suspension / Brakes / Handling
71
Jul 8, 2013 05:19 PM
Speed Element
Evo 'For Sale' Suspension / Brakes / Handling
25
Nov 11, 2010 06:16 PM
Speed Element
61
Sep 25, 2008 11:36 AM
Speed Element
Nov 28, 2007 10:38 AM
Kami Speed
53
Feb 5, 2007 03:48 PM
