Whiteline!!, Ohlins, KW, Bilstein, Swift and Custom KW V3's!!!
Whiteline Geometry and Bushing Package - Still $419!shipped
Whiteline Roll Center Kit
Whiteline Bumpsteer Correction Kit
Whiteline Rear Trailing Arm Bushings
Whiteline Front Control Arm Bushings
These Whiteline Geometry and Bushing parts correct the adverse effects of lowering an EVO while removing a lot of the "slop" from the stock bushings. Firmer bushings prevent dynamic changes in camber, caster, and toe, while the Roll Center Kit relocates the roll center of the car, correcting a side effect of lowering an EVO.
These parts make a great addition to GTWorx Suspension Stages or any coilover system.
Ohlins DFV
Ohlins DFV Sportlines for EVO 8 and 9
$2695 shipped.
The MSRP on the Ohlins DFV's is $3195. You are saving over $500!
These are rebound adjustable, threaded body dampers. Height is adjustable at the spring perch and the lower mount for separate preload and ride height adjustment. Front camber plates and rear pillowball mounts are included. Everything you need to put on one of the best handling and riding suspensions for you EVO 8 or 9.
We've worked extensively with the Ohlins DFV Sportline for EVO 8 and 9 kits with DaWorstPlaya, who tracks, autocrosses, and daily drives his car. We can provide real, experienced suspension feedback, guidance, and after sale support. We are suspension people who work with this stuff everyday and understand the theory and real world application of these parts.
If you have any questions, feel free to give us a call or PM us.
- Andrew
SmikeEvo Handling Package
Swift Sport Springs (Spec R's available too, add 15 bucks)
Bilstein HD dampers
Swift front and rear swaybars
$1569 shipped!!!
SmikeEvo helped pioneer the new wave of modding EVO suspensions....and that is you can get great handling and great ride quality at a great price. Without coilovers.
We also offer the same package with Whiteline front and rear swaybars at $1435 shipped.
Threads with his reviews:
https://www.evolutionm.net/forums/ev...-reviewed.html
https://www.evolutionm.net/forums/sh...d.php?t=337211
https://www.evolutionm.net/forums/sh...d.php?t=342041
Call 410-579-1501 to order!
Standard KW rates are 9k front 6k rear. That's not very good and IMO a total waste on a great coilover. These things NEED better rates, and we're the ones to offer it.
Introducing our KW V3 Spring Upgrade Package. 9k/6k is a little off for the EVO and the result is not ideal for the track or street IMO. Great shock, but understeer, and okay ride quality. Lots of room for improvement. I've looked at the shock dyno plots of the off the shelf KW V3 kits and have designed 2 different spring packages (mild and spicy) that match the standard valving and are well within range of the shock. The rates were chosen to match the motion ratio of the rear on the EVO. We have tons of experience with KW and know what they are capable of when set-up correctly, so this is primarily designed to complete the KW package.
We use Swift coilover springs for the Mild. Hyperco is available for the Spicy set-up. The standard KW spring perches, helper springs, and hardware can all be reused.
Mild is one of the best all around street/track/auto-x for fun set-ups i've driven. It's not a nationally competitve auto-x set-up, but it's just plain fun. Well balanced, easy to drive, and comfortable.
Spicy is intended for someone who is a little more interested in track days and auto-x. Still rides pretty well on the street. I'd recommend this set-up if you run wider tires or r-comps. Another well balanced, easy to drive, fun set-up.
Call for extra spicy.
KW V3 with Spicy GTWorx Spring upgrade package
$2249 shipped with Hyperco Springs
KW V3 with Mild GTWorx Spring upgrade package
$2449 shipped with Swift Springs
Call or PM for more info.
- Andrew
- Andrew
Don't forget that we still can get you guys the GTWORX Evo springs if enough interest is there. Check out these threads for more information.
https://www.evolutionm.net/forums/ev...group-buy.html
https://www.evolutionm.net/forums/ev...k-springs.html
https://www.evolutionm.net/forums/se...ine-cusco.html
https://www.evolutionm.net/forums/ev...o-springs.html
https://www.evolutionm.net/forums/ev...gs-review.html
http://sevo.motionforum.net/suspensi...basic-t263.htm
https://www.evolutionm.net/forums/se...works-rce.html
https://www.evolutionm.net/forums/ev...e-springs.html
