Evo 'For Sale' Suspension / Brakes / Handling Includes pads, rotors, springs, shocks, swaybars, and other handling related components.
DBA 4000 Series Slotted Rotors + Hawk HPS Street Pad Combo - Just $599 SHIPPED!!
Old Sep 14, 2009, 10:32 AM
EVOBrakes's Avatar
KNS Brakes has been a stocking distributor for both DBA Brake Rotors and Hawk Brake Pads since 2005.
We ALWAYS have the best deals here on EVOm.
AIM = rotordude69
www.knsbrakes.com
MFG Info:
DBA 4000 Series Rotors are a mid-series enhanced performance rotor. These rotors feature Thermal Stability Profiling (TSP) for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring.
DBA makes one of the finest high quality rotors on the market.
** Included in this DBA/Hawk Combo Sale are the following parts**
4418SL and 4418SR - DBA Front 4000 Series Slotted Rotor Pair
4419SL and 4419SR - DBA Rear 4000 Series Slotted Rotor Pair
HB453F.585 Hawk Performance Front Brake Pads
HB180F.560 Hawk Performance Rear Brake Pads
CLICK HERE TO BUY NOW
Current $149 Pad Specials on Hawk HPS Front and rear!!
BUY NOW HAWK HPS $149!!
Front and rear blank rotors - in stock and $175 for all four!!
BUY NOW
Substitute DBA standard slotted rotors with Hawk HPS pads and you pay only - $569
!!! SPECIAL !!! SPECIAL !!! SPECIAL !!! SPECIAL !!!
DBA 5000 2-Piece rotors 52218BLU SL/SR
EVO 8,9 MR
DBA 5000 2-Piece rotors 52218RED SL/SR
EVO 8,9 MR
We have only 1 pair Blue and 1 pair Red at this price.
Blow Out Special for DBA 5000 series rotor ..... $550.00 + S&H (Please PM or Call)
PFC 2 piece EVO 8, 9, MR Rotor Pair
We have 3 pair at this price.
Blow Out Special for PFC 2-Piece Rotors ..... $600.00 + S&H (Please PM or Call)
PFC-Z rated Front & Rear Brake Pads
BUY NOW
Front and rear Centric Posi-Quiet semi metallic brake pads are - $80!!
Front and Rear SP Performance Slotted rotors - $399
We stock Hawk, Ferodo, Centric, Carbotech, and other brake pads.
We stock DBA, Centric/Stoptech and SP Performance brake rotors.
We stock ATE and Motul fluids and Techna Fit lines.
We also offer PFC street and track pads fro EVO's.
We carry Brembo and Stoptech BBK's.
To order please call us at 919-376-1554 or drop us a PM for an easy online transaction.
Visa, Mastercard, American Express,Discover Cards and Paypal accepted.
Local pickups are always welcomed.
Thanks for the Support EVOM!!
And the shark move just added
EVOBrakes is offline
Old Sep 14, 2009, 12:18 PM
EVOBrakes's Avatar
Worth Bumping at these low prices
Old Sep 14, 2009, 12:28 PM
TS8
TS8's Avatar
How much for just the dba4000 rotors for all 4 discs shipped to 11204?
I'm debating EBC on eBay or your deal if the price is close enough. Thanks!
TS8 is offline
Old Sep 14, 2009, 03:07 PM
EVOBrakes's Avatar
You have PM sir.
Old Sep 14, 2009, 04:39 PM
EVOBrakes's Avatar
Thanks for the calls!
Old Sep 15, 2009, 06:15 AM
EVOBrakes's Avatar
Bump TTT
Old Sep 15, 2009, 12:31 PM
EVOBrakes's Avatar
CA Bump
Old Sep 16, 2009, 05:27 AM
EVOBrakes's Avatar
Wednesday Bump
Old Sep 16, 2009, 02:59 PM
EVOBrakes's Avatar
Late afternoon bump
Old Sep 16, 2009, 05:13 PM
EVOBrakes's Avatar
bump again - plenty in stock guys
Old Sep 17, 2009, 06:25 AM
EVOBrakes's Avatar
Back on top
Old Sep 17, 2009, 10:41 AM
EVOBrakes's Avatar
To the top
Old Sep 17, 2009, 02:58 PM
EVOBrakes's Avatar
Thursday bump
Old Sep 17, 2009, 07:48 PM
TS8
TS8's Avatar
Great deal you got going, especially the $599 deal - wow!!
Which brake fluid do you recommend for daily driven Evo for the street (I guess looking for longevity more than boiling point).
And how many bottles or liters/ozs do I need for entire system flush??
I'll be ordering the $599 DBA/Hawk combo with the fluid you recommend. Thanks!!!
TS8 is offline
Old Sep 18, 2009, 08:16 AM
EVOBrakes's Avatar
One of the funniest things I see is "Stage 2 kits" with street pads/rotors/brake lines.....AND HIGH DOLLAR MOTUL RACING BRAKE FLUID
Usually it's RBF600- a 600 degree racing brake fluid that is $40/liter.
Talk about the unnecessary upsell...
In order to take advantage of that fluid you would have to roast street pads into oblivion. And it deteriorates more rapidly.
A quality DOT4 fluid will easily suffice if you are running street pads. And it's more important to follow the maintenance schedule and flush/bleed appropriately than actually what fluid you use. I would avoid some no name AutoZone junk - but that's about it.
Example -
Valvoline Synpower
VALVOLINE SYNTHETIC DOT 3 & 4 BRAKE FLUID
• Exceeds DOT 3 & DOT 4 Specifications
• For disc, drum or ABS brake systems
• Dry boiling point exceeds 500°F
Valvoline's Synpower High Performance Brake Fluid is recommended for all ABS, drum or disc brake systems which specify either DOT 3 or DOT 4 brake fluid. Its premium low moisture formulation with a dry equilibrium reflux boiling point greater than 500°F provides superior performance even under severe conditions. As brakes generate heat, brake fluid must remain liquid, without boiling to operate properly. Valvoline Synpower High Performance Brake Fluid is compatible with conventional brake fluid and meets SAE J1703, FMVSS No. 116 and DOT 4 specifications.
1. Follow vehicle manufacturer's recommendations when adding brake fluid.
2. Keep brake fluid clean and dry. Contamination with dirt, water or petroleum products may result in brake failure or costly repairs.
3. Store brake fluid only in its original container. Keep container clean and tightly closed to prevent absorption of moisture.
4. Do not refill or reuse container.
Technical Data:
Appearance
Pale, Yellow Liquid
Dry ERBP F503
Wet ERBP F343
Viscosity @ -40°C
1800 max
Quick Reply: DBA 4000 Series Slotted Rotors + Hawk HPS Street Pad Combo - Just $599 SHIPPED!!
