SAVE BIG with MAPerformance on Ferodo, Stoptech, Rotorpros, Racing Brake and MORE!!!!
The MAP Race Program | Why Choose MAP? | Our Services | Inventory Clearance | What Our Customers Say About Us |
From daily drivers to fully dedicated track cars MAPerformance has the experience and knowledge to get you the right combination to meet any need on any budget.
RB (RacingBrake) - Not a big name like Brembo or AP. No complicated brake theories, misleading claims or fabricated data. No gimmicks. Simply great brakes at great prices!
Curved Vane
This rotor is upgraded from OE straight vane to curved vanes as we deem necessary for performance, as most people are aware that curved vanes pump more air and keep disc cooler than straight vanes, however the curved vane discs are “directional” meaning left and right discs are different and requires two sets of tooling instead of just one set in the case of straight vanes.
Reinforced Rib
This patent-pending design is added to improve the strength of the rotor based on our exclusive design criteria of “Torque Ratio”. The result is that our rotors don’t have the same problem of warping like OE which others copy, and the auto enthusiasts love our rotors because the replacements end with our better design for a stronger and cooler rotor (ribs also increase air circulation).
RB is always in stock here at MAP orders can ship same day in most cases!
Custom machined rotors specifically designed around your needs. Whether your after blank OEM style rotors or zinc coated, slotted and drilled track ready rotors we have what you need!
Ferodo DS Performance brake pads give consistent braking where others may fade. When the going gets hot Ferodo DS Performance brake pads will stop you again, and again...always safely.
Ferodo DS Performance brake pads also have excellent water recovery characteristics, which enable you to regain maximum efficiency quickly - not miles later.
Ferodo DS2500 are always in stock here at MAP, place your order now and we can ship them out the same day!
Stoptech is known for offering some of the best big brake kits in the world. We are here to spread the word that they also offer a full line of brake components from SS brake line kits to high performance brake pads and everything in between.
Please contact us for unbeatable pricing on these products, also keep in mind we will match or beat any competitors pricing on so called "package deals"!
: Send us a PM|||||: AdamAtMAP|||||: 763-545-3800|||||: Adam@MAPerformance.com
