BC|KW|TEIN|CUSCO|EIBACH|SWIFT|WHITELINE|HKS|HAWK|S TOPTECH|KSPORT & More..Low Prices!!
BC|KW|TEIN|CUSCO|EIBACH|WHITELINE|HKS|HAWK|S TOPTECH|KSPORT & More..Low Prices!!
![](http://i892.photobucket.com/albums/ac124/echelonauto/EchelonForum.jpg)
You tell us what you would like a deal on today and we will get you the best pricing! 100% Satisfaction Guaranteed!
We understand you already have your favorite company to work with and are used to, all we ask is that you give us the chance to earn your business.
Head over to our Facebook Page at Echelon Autosports and "LIKE" us to recieve Weekly New Products Updates, Special Sales/Promotions and to just plain check out whats going on around the shop!
LET US BEAT THE COMPETITORS PRICE. PM US YOUR QUOTES TODAY!
Echelon Autosports carries a very extensive variety of Suspension Systems and Components. Coilovers, Springs, Sway Bars, Strut Bars, Under Body, Mounts, End Links, Handling Arms and more. We strive for excellent customer service and providing you with the lowest prices around. If you find it cheaper somewhere else, we will meet or beat those prices! Take a look at what we have to offer then PM us for Discounted Pricing. Give us a chance to earn your business and you wont be disappointed. Select parts IN STOCK!! Customer service and satisfaction is our number one priority.
Click Here to View Our Entire EVO Suspension Catalog
Coilovers From:
AST / FORTUNE AUTO / HKS / KSPORT / KW SUSPENSION / TEIN & More.....
Click Here to View our Entire Catalog of Evo Coilovers
![](http://vrechise.com/getimage.php?i=teinevomonoflex.jpg)
BC RACING COILOVERS
We have unbelieveable prices on BC Racing Coilover Systems
Want an Amazing Deal??? PM us for the Best Pricing Available
We have the TUV approved BC Racing Coilovers In Stock
Coilovers From:
BC RACING COILOVERS
![](http://i18.tinypic.com/2edw3yd.jpg)
![](http://i13.tinypic.com/4ct42fs.jpg)
BC Racing BR Coilovers
Features-
*53mm Dampers (larger then the competition)
*fixed cup/locking collar design (unlike cheap coilovers will not change ride heights, change camber, and wear out your tires!)
*Full pillowball mounts front + rear
*30 way adjustable
*optional rear extenders so you do not have to take out the rear seat every time to change the range on the dampers
*Clicks when you turn the damper handle so you can keep track of position
*1 year warranty
PM for the Best Pricing Available
BC Racing ER Coilovers
BC Racing ER Coilovers...the much anticipated External Reservoir, double adjustable coilovers are finally available for 02+ wrx/04sti, 05-07 STI, And both the 08+WRX and 08+STI. whats new about these? It features Large external reservoirs front + rear, Separate reboung and compression adjustments and a twin piston design. The external reservoirs hold much more fluid then coilovers without to allow the car to operate much longer before over heating on the track. The external reservoirs also house the secondary piston, which allows for the fine tuning of compression. This is the perfect coilover system for the person who wants to fine tune their setup using the separate, 30 way, rebound and compression dials.
Features-
*External reservoir Mono-Tube shock design
*30 levels of damping force adjustment, adjusts both compression and rebound separately
*Twin Piston Design
*Pillowball mounts and adjustable camber plates included (where applicable)
*Adjustable rear camber plates available
*Separate full length height adjustable
*One year warranty
*rebuildable
This is the coilover system BC Racing used to win many races this past season in the redline time attack. If you are serious about handling, dont pass these up. PM for the Best Pricing Available.
ISC N1 COILOVERS
![](http://forums.nasioc.com/forums/images/statusicon/wol_error.gif)
![](http://i41.tinypic.com/332sd95.jpg)
![](http://i40.tinypic.com/29vctpl.jpg)
Warranty! All coilovers come with 12 month warranty to put your mind at ease
if their product fails in any way in the first 12 months they will pay all postage, labor and parts costs to fix the problem in minimal time.
Features-
The N1 coilover can be lowered approx 3 inches lower then standard ride height, this along with a spring rate setup to suit your car improves handling and stability dramatically.
ISC makes packages for drift/rally/drag and of course street, to help our customers out even more we give them the option to pick there own custom spring rates at no extra charge.
32 Step Damper Adjustable
Precise control damp valve
Operates smoothly on all road surfaces
Expansion/Suppression of shock adjustment Pillowball Uppermount
Adjustable camber allows more/less on road track for all conditions Piston Rod Design
High rigidity steel piston rods
Meets with race/sport standards Sports Spring
Made from high quality SAE9254 steel
Tested over 500,000 times on compression inspection with less than 5% deformation
Ride Height Adjustable
Full length height adjustable
Bound adjustable with separate spring locks
High quality T6061 aluminium alloy used for all adjustment locks to provide a lightweight design that holds spring and vehicle down force Aluminium Bracket
Specifically anodized surface to prevent inside corrosion and surface rust
On various models camber can also be adjusted via the bracket as well as the camber tops Single Cylinder Design
Larger cylinder and piston design to advance driving stability and dexterity
Fortune Auto 500 series coilovers
![](http://i36.tinypic.com/2agkxzb.jpg)
- Dyno tested
- Stainless steel body / piston
- 30-way adjustable dampers
- Pillowball mounts
- Forged aluminum locking collars
- Dust boots on all pistons
- 50mm piston (beyond the industry standard of 44-47mm)
- Anodized aluminum camber plates** on front upper-mounts
- Fully anodized body
- 1 year Manufacturer's Warranty
- Height adjustment independent of preload
- ISO 9002 certification
Applications- http://www.fortune-auto.net/applications.htm
Lowering Springs From:
Eibach | Espelir | H&R | Skunk2 | Tein & More.....
Click Here to View All Evo Lowering Springs Available
![](http://vrechise.com/getimage.php?i=eibachspring.jpg)
Sway Bars From:
Agency Power | Cusco | H&R | Hotchkis | Perrin | Progress & More.....
Click Here to View Our Entire Catalog of Evo Sway Bars
![](http://vrechise.com/getimage.php?i=pep-sus-200_1.jpg)
Many More Suspension Parts and Accessories Available....Visit WWW.ECHELONAUTOSPORTS.COM to check out our Entire Catalog
- Dyno tested
- Pillowball mounts
Sway Bars From:
