Stance Coilovers available through DynoTech Tuning!
Stance coilovers are now readily available through your friends at DynoTech! Introductary special on ALL UNITS!!!! There is a range from a standard street coilover to all out drift/autocross whatever your application might be Stance and DynoTech will have you covered!
The GR+Plus is our flagship line. It features 15-way damping adjustable monotube shocks, which allows the driver to fine-tune the handling and ride. A separate lower bracket allows the ride height to be adjusted without sacrificing stroke. Spherical bearings are used to give the driver greater feedback. Inverted monotube shocks are utilized on strut types for greater rigidity and heat dissipation. Camber adjustable upper mounts are used on strut types.
GR+ Pro coilover has all the features of the GR+ but adds the benefit of a helper spring. The helper spring allows the shock piston to be placed in the optimal position within the shock body, increasing rebound stroke, and maximizing articulation on cars with minimum suspension travel.
SS-D The Special Setting Dampers were developed to meet the special demands of the circuit. The SS-D is valved to work in conjunction with race tires to maximize traction. The GR+ Pro SS-D were used to win national titles in both drifting and time attack; setting the highest benchmark for itself - winning.
XR is our top of the line single way adjustable coilover. XR features industry leading large 60mm OD casing, which reduces rod pressure for consistent performance.The newly desgined "sensing" piston responsds with full damping capability within as little as 2mm of shaft movement. Instant reaction to changing road surface equals traction and comfort.
GR+2Way is our top of the line coilover. The GR+2Way features 2-way adjustability, enabling the driver to fine tune compression separately from rebound. An external reservoir is connected to the damper using specially designed fittings that allow the line to swivel and disconnect for packaging and servicing convenience. An optional tool is also available to adjust the gas pressure to give the driver the ultimate adjustment control.
GR+3Way is our top of the line coilover. The GR+3Way features 3-way adjustability, enabling the driver to fine tune low-speed and high-speed bump separately from rebound. An external reservoir is connected to the damper using specially designed fittings that allow the line to swivel and disconnect for packaging and servicing convenience. An optional tool is also available to adjust the gas pressure to give the driver the ultimate adjustment control.
Take advantage of special EVOm Pricing!
Email me today! Shoot us a PM
Adam@dynotechtuning.com
Speed Element
EvoX 'For Sale' Suspension / Brakes / Handling
60
Dec 7, 2012 09:21 PM
CIP Motorsports
Evo 'For Sale' Suspension / Brakes / Handling
Dec 5, 2008 07:56 AM
CIP Motorsports
10
Oct 13, 2008 07:48 AM
Vaughn Performance
22
Aug 15, 2008 04:52 PM
