Evo 'For Sale' Suspension / Brakes / Handling Includes pads, rotors, springs, shocks, swaybars, and other handling related components.
Best Prices on ALL Ksport Products!
Old Jan 17, 2012 | 04:01 PM
Vivid Racing's Avatar
Vivid Racing will match or beat ANY advertised price from an authorized Ksport dealer!!
The Kontrol Pro coilover is great for those enthusiasts that want to address the stock suspensions shortcoming while driving the car on the street with occasional track use. This system is great for you guys that race on Sunday and drive to work on Monday. The pillowball top mount on the front allows for camber adjustment, and provides better feedback to the driver. The rear uses a high quality aluminum top mount. Spring rates are 8.7kg/mm(487lbs/in) in front and 7.2kg/mm(403lbs/in) in the rear. Ksport offers an 18 month warranty and services their products in the USA.
Key Features
  • 36 levels of adjustable damping
  • Made from high quality 6061 aluminum with T6 for increased hardness
  • Compression/Rebound adjustable
  • Adjustable spring perch for height adjustment
  • Adjustable body allowing maximum suspension travel
  • Pillowball top mount with adjustable camber (not available for some models)
  • Monotube high pressure design reduces oil leakage
  • Electroplated body for protection from corrosion and rust
  • One year limited warranty
The Ksport GT Pro coilover system is the next step up in the Ksport line. The GT Pro steps up to an inverted monotube damper, which adds strength and increases high temperature performance. These coilovers are excellent for cars that see serious abuse on the track. The GT Pro uses the same high quality top mounts (pillowball front, aluminum rear), and the same spring rates as the Kontrol Pro. Custom spring rates are available on all Ksport coilovers. PM me for more info.
Key Features
  • Inverted steel shock absorber for durability
  • Lower center of gravity and higher chassis rigidity
  • Designed to reduce friction for cooler shock oil temperature
  • Inverted design like vehicles in WRC and all JGTC cars
  • 36-way adjustable damping
  • Made from high quality 6061 Aluminum with T6 for increased hardness
  • Adjustable spring perch for height adjustment, Adjustable body allowing maximum suspension travel
  • Pillow Ball Top Mount w/ adjustable camber (not available for some models)
  • Monotube High Pressure Design reduces oil leakage
  • 18 Month Limited Warranty
Ksport Rally AR Spec Damper System is designed specifically for asphalt rally competition. It features extended stroke, heavy-duty internals, and simultaneous compression and rebound adjustment.
Key Features
  • Special designed springs for rally conditions
  • Extended piston stroke
  • Reinforced internals to withstand extreme track conditions
  • Pillow ball top mount w/ adjustable camber (not available for some models)
  • 18 Month limited warranty
Ksport Rally Spec GR Type Damper System is designed specifically for gravel rally competition. It includes longer stroke, durable construction, and simultaneous compression and rebound adjustment.
Key Features
  • Extended Piston Stroke
  • Compression/Rebound adjustable, Adjustable spring perch for height adjustment
  • Pillowball top mount w/ adjustable camber (not available for some models)
Old Jan 26, 2012 | 02:47 PM
Thanks for the PMs guys!
Old Jan 31, 2012 | 01:24 PM
Last day of the month and need to hit a big goal. Any order helps so lend a hand! Contact me for special pricing.
Old Feb 7, 2012 | 05:42 PM
Back to the top!
Old Feb 15, 2012 | 03:04 PM
ttt
Old Mar 2, 2012 | 01:40 PM
You think you can find a better price on Ksport? Try me!!
PM me with ANY advertised price from an authorized Ksport distributor, and I'll beat it.
Old Mar 6, 2012 | 03:02 PM
ttt
Old Mar 16, 2012 | 10:05 AM
ttt
Old Mar 22, 2012 | 02:18 PM
ttt
Old Apr 12, 2012 | 12:30 PM
ttt! Let's move some Ksport stuff!
Old Apr 23, 2012 | 10:47 AM
Crazy pricing on anything Ksport! PM me for details!!
Old May 1, 2012 | 07:33 PM
xtinstaaflx's Avatar
Can I get a quote for a 04 350z? Thanks
Old May 7, 2012 | 12:47 PM
Pm's pricing
LSD Motorsports
Vendor Classifieds
10
May 18, 2017 04:19 PM
IMPORTIMAGE
Lancer Vendor Classifieds
378
Jul 13, 2016 07:51 AM
IMPORTIMAGE
Lancer Ralliart Vendor Classifieds
138
Jul 13, 2016 07:33 AM
IMPORTIMAGE
EvoX 'For Sale' Suspension / Brakes / Handling
May 17, 2010 12:29 AM
DrivenConcepts
47
Aug 7, 2006 09:30 PM
