Save Big on Coilover Systems - KW, BC, D2, ISC and More!!
Providing EvoM Members with unbeatable prices since 2007.
If you can find a better price on any item, message us and we will beat it!
D2 Coilovers In Stock!!
D2 RS Series Coilovers - $1025 Shipped
Ask About Our AWD Custom D2 DRAG Coilovers!
(pm for exclusive pricing)
Key Features:
36-way adjustable dampening
Made from high quality 6061 Aluminum with T6 for increased hardness
Compression/Rebound adjustable
Adjustable spring perch for height adjustment
Adjustable body allowing maximum suspension travel
Pillow Ball Top Mount w/ adjustable camber (not available for some models)
Monotube High Pressure Design reduces oil leakage
Electroplated body for protection from corrosion and rust
One Year Limited Warranty
_____________________________________________
BC Coilovers In Stock!!
BC BR Series Coilovers - $999 Shipped
Key Features:
The BR-series coilover kit is perfect for street driving and occasional road course duty. With easily accessible ride height, having a performance coilover system couldn't be easier. You chose how low or high you want your vehicle (no preset ride heights here), and the patented concave lower locking ring keeps it locked in. All systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. Available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive-looking coilover system
Mono-tube shock design
30 levels of damping force adjustment, adjusts compression/rebound
Pillowball mounts / adjustable camber plates included with certain applications
Rear racing camber plates optional
Separate full length height adjustable
One year full warranty
Rebuildable after 1 year warranty expires for only $95 for life!
ISC Coilovers In Stock!!
ISC N1 Coilovers - $955 Shipped
Key Features:
Now come with thrust bearings
32 Step Damper Adjustable
Precise control damp valve
Operates smoothly on all road surfaces
Expansion/Suppression of shock adjustment Pillowball Uppermount
Piston Rod Design - High rigidity steel piston rods
Made from high quality SAE9254 steel
Ride Height Adjustable
Full length height adjustable
Bound adjustable with separate spring locks
Aluminium Bracket
Specifically anodised surface to prevent inside corrosion and surface rust
Single Cylinder Design
KW V3 Coilovers In Stock!!
KW V3 Coilovers - $2699 Shipped
Key Features:
The new Variant 3 is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up.These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the high speed set-up, so decisive for driving comfort, has been preset by our engineers.
Variant 3 race technology for the road with adjustable compression and rebound damping
Independently adjustable damping technology -rebound and compression damping
"inox-line" stainless steel technology
Individual height adjustment
German TUEV-tested adjustment parameters
High-quality components for long life
Comprehensive documentation for ease of use
Infinitely adjustable rebound damping
14- level adjustable compression damping
Unique, independently functioning damping power adjustment
If you are in need of any Coilovers that are not listed
PM us and we will get them for you at the absolute lowest price!
MENTION THIS AD TO RECEIVE SPECIAL PRICING
