White Gauge Cluster Installed
I finally got those AutoBudget gauge clusters i heard so much on this board about and decided to document the install. Here are the pics to the 45 mins (with bathroom break), hehehe. As you can see, the taking out part is easy:
1. 2 screws underneath the cluster face.
2. Then 3 screws behind the cluster protective face
3. Then yank (easy) the entire cluster collection out.
4. Overlay the white faces over the OEM black ones.
5. Put em back in,...but before that of course connect red wire to yellow-red wire on white 21 pin,...and ground the black somewhere metal, cut the loom in comes in to get more length out of it.
6. Connect all the plugs it came with and put the red-blue toggle switch inside the little coin-whatnot box under the steering wheel.
DONE
DONE
Undie.....I see in the pic you posted that you have a flip screen with gauges on it. I have been searching for this myself for my EVO. What deck are you using? How many gauges can you get on your screen? Any info you can give would be really helpful. Thanks
-CI
-CI
Originally Posted by AutoEuphoria
I believe that's a Pioneer AVIC N-1 or N-2 unit. It's a DVD/CD/mp3/etc player with a flip-out screen. Also comes with navigation software and the ability to wire into the car's speedometer and tach, along with a compass (the three gauges you see). It's expensive though...like $1000+
yeah... i have the same one and it is awesome. thinking of upgrading the software up to n2 model to get all the traffic info on the screen. also trying to find out how to add more gauges, if possible.
