New Front Lip
black makes the front end look higher on white from a distance.. a color that sticks out would make it look lower...
Originally Posted by stvbreal
Told you it looks better on white.
You did a great job.
Originally Posted by 03BREvo8
how long did that take to paint and what did you mask it off with?
1) Remove the plastic under tray
2) Remove about 15 phillips head screws. (This was the hardest part casue I don't have a jack to lift the font end up.)
3) I than wash it with regular car soap.
4) Sand with 400 grit sandpaper. (Not trying to remove the paint but rough it up so the new paint will stick. I used about one sheet.)
5) Spray w/ your choice of color. (I used Dupli-Color Bumper {Black} paint.) I put about 3 coats on. Don't overspray though. Waited about 30-45min for each coat to dry. Might need more time to dry though.
6) Put your new front lip on.
Took about 2-3hrs
