How to Install a ZakleeCorp Clear Cam Gear Cover
Not really much to the install...
1. purchase a Zaklee Sightglass Clear Cam Gear Cover
www.http://www.zakleecorp.com
2. use a 10mm wrench or ratchet w/ 10mm socket
btw - this cover will fit aftermarket cam gears and evo engines 4-8
Step 1
Unpack your new cover
![](http://www.hostdub.com/albums/burningmoney97/clear_cam_cover_1.sized.jpg)
Step 2
Remove the 4 bolts from each corner of stock cover
Bottom left bolt is the most difficult to remove
Step 3
Set aside old cover
Step 4
Install new cover
![](http://www.hostdub.com/albums/burningmoney97/clear_cam_cover.sized.jpg)
Step 5
Reuse the stock bolts from the old cover and tighten
Step 6
Start your car and watch
![](http://www.hostdub.com/albums/burningmoney97/cam_cover_11.sized.jpg)
Step 1
Step 2
Step 3
Set aside old cover
Step 4
Install new cover
Step 5
Step 6
I can not get this thing installed. For one i have to take a bolt out of a bracket that holds a hose away from the cam gears, i have to do that just to have a little room to try to slide the cover in. Plus the end of that hose is right in front of the bottom front bolt so i don't see how i am supposed to unscrew that (i guess i could get in there with a 10mm open ended wrench). The one in the back i can barely see so i guess when my engine cools some more i will try to get a socket on it. It must be because the fidenza cam gears are much thicker than stock or something because there is no way to slide a cover in there without taking out other bolts.
btw- i only used three bolts to hold it down. left out bottom left. havent had any problems without it
Originally Posted by burningmoney97
its not an easy slide in. have to put some muscle into it to get it down. but if you can get the stock cover off then you can get the new one it.
