apr canard placement
hmmm........interesting angle. How is turn in? I believe if you go too far with the angle there will be more drag rather than downforce. I'm not too sure, I am just starting out in aerodynamics as a pilot but let me read you this. This is referring to airfoils on air or rotorcraft. I believe it's universal though. "When the angle of attack is increased, air flowing over the airfoild is diverted over a greater distance, resulting in an increase of air velocity and more force(lift or downforce). As angle of attack is increased further, it becomes more difficult for air to flow smoothly across the top of an airfoil. At this point the airflow begins to seperate from the airfoil and enters a burbling or turbulent pattern. The turbulence results in a large increase in drag and loss of lift or downforce in the area where it is taking place. "
hope that helps.
hope that helps.
i agree i also found a diff in the front end while driving...
if i understood it correctly ur talking about a wing which creats lift in a diff way much like the rear wing on the evo 8s and 9 where if u were to take a cross section its more bowed on one side so the air particals must flow faster along that surface crateing a depression therefore sucking up on the wing (down in our case since its reversed)http://www.indiana.edu/~bradwood/eag...osssection.gif
but in theaory ur still right if the angel on the canard is too strong then drag becomes heavier and therefor minamizing ur efforts
MrMejia: hmmm........interesting angle. How is turn in? I believe if you go too far with the angle there will be more drag rather than downforce. I'm not too sure, I am just starting out in aerodynamics as a pilot but let me read you this. This is referring to airfoils on air or rotorcraft. I believe it's universal though. "When the angle of attack is increased, air flowing over the airfoild is diverted over a greater distance, resulting in an increase of air velocity and more force(lift or downforce). As angle of attack is increased further, it becomes more difficult for air to flow smoothly across the top of an airfoil. At this point the airflow begins to seperate from the airfoil and enters a burbling or turbulent pattern. The turbulence results in a large increase in drag and loss of lift or downforce in the area where it is taking place. "
hope that helps.
hope that helps.
EVOEvolved
10
Sep 1, 2016 10:12 AM
oneofakindracer
15
Nov 5, 2011 03:25 AM
