yellow highbeams
yellow highbeams
i was wondering if any of u have ever or know that if u can change out ur highbeam bulb and put in a yellow 1s so that it illuminates better when u REALLY need to brighten things up...since our bumpers arent really drivin lights capable like the older gens...and i dont wanna use that yellow protection film and have everything yellow....
thanks,
Ray
thanks,
Ray
Originally Posted by chronohunter
yellow lights=less light=French=ghey
but hey, have at it, what the h*ll do I know
well i was thinkin just the highbeams....and yellow lights arent less lights is it?? cause i thought though it seems less but it actually illuminates better then white light....
another thing is, can someone tell me what all the bulb codes mean?? like...i see in the owners manual that the bulb type is a HB3/9005....does that mean that i need to use a H3 bulb at the capacity of 60W?? and i saw the PIAA PLASMA ION YELLOW...anyone know anything about it?? like if itll work on the highbeams? or maybe i should consider doin it to the actrual fog lights??
You have to use 9005/HB3 bulbs, they are not the same as H3.
Any "colored" halogen bulb uses a filter to make the light a color other than the original shade of white. These filters block some light to create the color, so they are not technically as bright as they could be, but it's minimal.
If you want brighter lights, you can use up-wattage bulbs. Typically the Evo low beams (9006 bulbs) are 55w, but you can buy 80w replacement bulbs. They will not last as long. (we're talking halogen of course here, not HIDs) The high beam bulbs (9005) are typically 65w, but you can upgrade to 100w.
I get my bulbs for our bikes and cars at www.rallylights.com and they have all of those mentioned.
yes....good info!! thanks for the link too!!
Originally Posted by WarmPepsi
if nothing else, when sitting, they look mean, like the freakin car is possessed
