I need to roll my FRONT fenders? (PIC)
#31
Originally Posted by voidhawk
you don't have to spent money on this problem. All you need to do is park your car in the hot sun for a while, put on a pair of gloves and gently pull out the front fenders with your hands. I got an easy 10 mm of clearance that way. The front aluminum fenders are so soft, they bend like butter.
#32
Originally Posted by onesicklambo
x2
voidhawk....so did you pull you front or rears? You posted the pic, but it's closer to the rear fenders and you said you did the front. So you don't have any damage in your fenders at all after that?
#33
dang i ordered these exact same wheels last week...but i will be running a slightly stretched tire to avoid this problem...
you could always buy wider front fenders...they arent too expensive
#34
If your running coilovers, might I suggest you raise the ride height a smidge. Not that it doesn't look good now but it might help to fix the problem.
Also, maybe run -2 on the camber.
evil03
1180
Sep 21, 2021 10:31 PM
PaulyX
18
Jul 21, 2016 08:35 AM
m.al-hassawi
52
May 20, 2015 09:28 PM
lightspeed1
12
Apr 3, 2007 09:23 PM
