no sound?
no sound?
ok guys get this i just finish installing my cusco 6pt roll cage in my Evo 9 MR without the infiniti system and the funny thing is my speakers now don't work. i have an alpine head unit but the thing is the headunit turns on and the CD plays but no sound any ideas?
where the middle hoop touches the floor it comes really cose to wiring/cables. Did you check and make sure is not pinching anything? Also did you take the carpet up to bolt it to the floor? POst pics too Another thing you mught try... take a paper clip and on the front of the alpine theres a TINY little hole(its a full reset button) hold it for about 5 sec(everryting will reset). Sometimes they just go bonkers and need a reset.
kool deal ill check it right now yeah i left the carpet in because i think it would look better then to cut the carpet ill post up pick after i get the radio to work do you know if the wiring is on the driver side or passenger side?
who has a cusco cage instock I need one asap
yeah it touching the headlinear but it not to bad i figured that carpet was going to cause problems but owww well i like the look of the cage on the carpet than having it cut but to wat i can see all the wires are runing on the sides of the car under the door sills and non of the wire looms are going towards the middle of the cage i am going to try and reset the deck now and will see what happens hahahhah
