Harness Help Please
M3This, the rules recently changed to allow 2" lapbelts... I have the documentation here:
http://www.scca.com/_Filelibrary/Fil...ulechanges.pdf
Check out item 5, 2" lap belts are approved for 6-pt systems as long as they are FIA certified (The Profi II is FIA certified).
I also would STRONGLY urge you to invest in a HANS device. They are expensive but can basically save your neck and mobility in the event of a crash, I wouldn't race without one after seeing a guy walk away from a 140mph crash in to a wall up at Mosport in an S2000 (which was completely wadded up). That plus the cage and harness saved his life.
Location: Where you come to vacation and go home on probation! Vegas!
Another question .... I was talking to the guy at HMS and he said unless the seats have the cut out for them not to use a 6 or 5 point harness system. I was looking at the Bride GIAS as the car is daily driven as well and those dont have the cuts out for the 5/6 point harnesses eaither that I can tell from the photos ... am I wrong about this? Do I have to get a Hardcore bucket seat?
I would reccomend against getting the Bride GIAS seat. You want a non-reclinable bucket seat with a sub strap hole for a 6 point system. I have the Bride ZETA III and love it, however it is for smaller drivers (Hope you are thin). If you really want a Bride, get the ZETA III, with a reclinable bucket seat you run the risk of it snapping at the seam where it reclines... and well I am sure you can imagine what happens next. Plus it doesnt have a substrap hole anyways so it's worthless
If the ZETA is too small, check out the Recaro Pole Position.
He is absolutely right. A seat without a substrap hole is in no way safe for a 5/6 point system. It pushes the subbelt forward and won't allow it to work properly. You run the risk of submarining by using the belts in this way. You DO NOT want to submarine, it is NOT pretty at all.
Im real thin but tall (6'2"), I had a set of Sparcos in the past but they wher too wide for me so thats why I was looking at the Brides to begin with. Do you think the Zeta III bucket is too much for daily driving ?
^^ I like Simpson harnesses also. We have them in our old '69 911 and they're excellent, easy to adjust and operate. We used them to replace the nice but worn out Willans we had. Willans are nice, but $$$. Plus, with the Simpsons, I bought direct from the company and was able to piece togather exactly what we needed. Make sure you mount the harness as directed, that's the key to keeping you safe. You've recieved a lot of good info about seats here too.
With you strapped into these, and the seats, you're STUCK, no questions asked. Anybody that's ridden with me on track can attest to that
You got the right idea, but how can you stand driving around knowing that your interior dont match????? that would kill me only having (1) seat and (1) harness...
To me thats like them honda dudes rolling round with 15" steels in front and 18" chromes in the back
how about these seats? They ask you when purchasing for an extra $58 to put a hole in the bottom of the seat for the 5 PT harness... does that make it ok if you are hypothetically running the proper harness bar (roll bar, or whatever)...
Would the qualify as okay?
http://www.racing-seats-usa.com/60091.html
