Is Fixing Semi-Deep Scratches Possible?
I have a few finger nail deep scratches (where u can start to see the white from underneath the paint) like one near my gas cap and one underneath my wing (wierd f*in places)
What im wondering is, is there any way, besides having them completly repainted, to have them fixed?
waxing and buffing hasnt worked.. any alternitives?
Thanks
Thanks
Location: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Originally Posted by hulkmanj99
u can wet sand them, then just buff buff buff and wax wax wax!
Edit: Some may recommend a clear coat on top, but if you're just filling scratches, it really isn't necessary.
Originally Posted by sscollision
if you can feel them there not coming out.
are there shops that just fix tiny scratches rather than repainting the whole body part like mitsubishi does?
i dont want to use touch up paint
Originally Posted by Pure Playaer
is this true?
BTW, I would think about doing it yourself. You can try first on a small stone chip or something similar.
i got a touch up pen from mitsubishi but when i tried to apply it to a small rock chip a while back before my bumper was repainted (friends mom backed into it by accident lol) it looked like ****!
If you can feel them, they are most likely to deep to buff out. The guy that was talking about filling them then buffing out the excess is about the best bet without repainting. The way it goes is this, if you can drag a fingernail across it and it catches on the scratch, then it needs repainted. The filling process with base coat until its above your finish, then colorsanding does work(I have done it before) but its just a bandaid solution and will not last. One would argue if you go the extra step and put a coat of clear on it before you sand it and buff it, it will last.....only it will last longer then just base, but not much longer. So think about this if you will, a couple of hundred every six months or so to redo that process, or 4 to 6 hundred ONCE to get your quarter resprayed? Your choice my friend.
Later Josh
Later Josh
