Rota P45R Wheel thread!!
#46
Come on fellas! We only need ONE more interested in these wheels.
The Royal Black P45R's will look hot on a WW IX RS too
#47
He means the ones with the 30 offset that the outer edge of the wheel sits flush with the fender.
It still has the concave look. It's the exact same setup that's on the red RS.
They're $900 shipped I believe......
#48
Corect, if you look at the photos with straight on front shots or rear shots of the wheels, you can see the +30MM offset is 'flush' with the top front fenders outer edge.
I'm sure camber also has a little to do with it too.
The +25MM offset on the other hand seems to protrude out a bit more beyond the front fenders edge.
All P45R's are concave in 18x9.5's
$900-/set with free lug nuts in the group buy.
#54
#55
We only need one more interested to sign up for these HOT wheels!
Guaranteed to give your evo a aggressive jdm 'Time Attack' look.
The +30MM offset size with 245/40/18 or 255/35/18 tires will fit with no fender rolling!
Not sure about wider than 255's though?
Rota P45R Royal Black with polished lip 18x9.5 with +30MM offset (flush look).
1) Evotech8
2) blackbichGSX
3)
1) Evotech8
2) blackbichGSX
3)
#56
Originally Posted by inco9nito99
Looks hot..what size/offset exactly? How much fender work/spacers? I'm trying to achieve that look with those wheels on my RS.
ps. how heavy is each wheel minus tyre?
These are 18x9.5 with a 25mm offset and a 5mm spacer in the front
Fender rolling will be needed in the rear, not sure about the front.
Each wheel is ~ 23 lbs
#58
#59
Whos car is this? i know they are the Rota P45r's but are they the 30 offset or the 25??? also what is the color called flat black??? thanks alot
One last thing, any idea on the suspension, car sits nice to me..
