Rota P45R Wheel thread!!
#121
Supposedly...... No mods if u get the 30 offset and don't go wider than a 255-35-18 and spacers up front. I'll let u guys know here soon. I'm suppose to get my car back from the dealer on Wednesday. I'll give a detailed thread on the fitment and specs and multiple pics of wheels/tires in relation to the front and rear fenders.
Anyone think I should do white on cosmic blue?
#123
#124
Was my description not enough? I probably gave the most detailed description in this thread even to the point of camber and toe settings. With +30 offset, you're going to need at least 5mm spacers in the front, 8mm to be safe. Rears will need fender rolling with 255 and up. There is no loophole around this.
#125
#126
I do believe you are incorrect about not needing to mod with 255s. I am 99% sure you will have to roll the rears only with 255s. 245s shouldnt require any mods though. I know that the guys running the 18x9 GTR face ADVANS need to roll the rears with 255s and they have +29 offset. So +30 or +29 isnt going to make a difference unless you consider 1mm enough clearance.
#127
#128
Cant wait to see the pics koffebean.
front fenders will scrub at times
#129
Really? 245s and +30 should be no problems I would think. When I was looking into getting RGIIs with the +29 offset, a ton of people ran 245s with zero issues. Most ran 255s with rolled rears though. Hmmm....it sounds like these things may be more trouble than they are worth.
#133
#134
#135
Really? Well can you please post up! Not to be a pain but I am **** when it comes to my car and this stretch shown here is just way too bad. And I dont want to run 265s if I dont have to as most say they barely rub, but still rub none the less. Also they cost a lot and throw crap all over the side of your car and I do not want to run mudflaps. Also, what brand/style of tire are you running? Some tires have thicker sidewalls that make the tire look wider when they really have the same 255mm contact patch. Thanks Bean!!
