How the stock boost gauge should be *Part 2
Well I'm back with my second attempt at making the lancer gauge into something useful. Im pretty happy with the way this one turned out. I didn't like the aluminum overlay as much as I thought I would. I think the stock look is the only way to go. The only problem with this gauge is that the face numbers are white. If anyone has any ideas to die or color them id like to know. Let me know what you think. Heres the howto https://www.evolutionm.net/forums/sh...d.php?t=249800
honestly the best thing i've seen since i joined here, i'm looking into gauges right now.
are you definetly doing a write up? if not is it simple enough to figure out on my own?
damn... thats the only gauge i can find in 45mm... it only reads 25psi
im running 26 right now and will run 28 soon.
i did a search on google, yahoo and ebay.
any companies that i didnt come across?
Yea, its not hard if you aren't afraid of cutting some stuff. The only thing that worried me was cutting into the circuit board on the gauge cluster. Ill show you what I mean. I followed all the traced and made sure they would be ok to cut, thankfully it all turned out ok. ^ It only goes up to 25 psi, I dont plan on going above that for a while.
edit: I just wrote up the how to, check it out here
