#7502
18x9.5 +22 te37 SL. No rub unless i cut the front wheels all the way to the drivers side and even then its only the liner in the wheel well
edit: didnt realize i used an instagram screebshot but **** it give me a follow haha
#7503
#7505
^You can make them fit but it requires a lot of work and murder to your fenders. Im running an 18x10.5 +30 NT03 with a 295/30 and it involved fender work up front (I failed rolling the fronts badly) so I spaced them out, fender liner modifications, 17mm spacer up front for me massaging here and there and then the rear involved a roll pull bumper bolt relocation massaged trailing arm especially around the e brake bracket and some other stuff I might be forgetting.
If you just want big wheels to have big wheels Im sure it won't involve as much if you plan to go with skinny tires but if youre planning on racing the car and want real meat proper clearance and modification is necessary.
eboogies (Oct 1, 2017)
#7507
Definitely should not have been posted in this thread bud. Your car does not meet the requirements... See below..
#7508
#7511
Astro_Train (Sep 8, 2017)
1hotevo9 (Jun 1, 2023)
#7515
Hey guys, I’m coming from the X world and have a set of custom spec meister S1R. I was wondering what the chances are of getting these to fit and not be completely useless in terms of driveability. The wheels are 18x10.5 +10. I am considering doing a voltex cyber kit but just wanted to know if I have any hope in terms of using them until the work is done. Thanks!
