Is this drop too low?
#32
Looks good!
I like it a lot man.. I'll be looking to make mines some what that low... maybe a little higher since I know I'll be doing serious street racing... But what size are those rims? 18x8.5?
#43
Evos are setup to have the front with more wheelgap....that's just the way they are. Lowering the front more would actually shift more weight to the front on an already front heavy car. It may "look" better to have the front and rear with the same gap, but as far as performance goes the front should have more wheelgap or stiffer rates than the rear.
#44
If that height is good for you then you should have the car cornerweighted. You paid extra for coil overs, you should take full advantage of them. Then you know they are exactly where they should be.
