any body dropped their evos
#31
#35
thank alot guys for the pics abd infos
i'm looking for something that could give me the stock handleing but dropped!
if i go with springs would that be better for me then coilovers , would it still have the stock hadleing if i change just the springs!!
please help me out!!
#38
your not going to get stock handling if you do anything to the height of the vehicle cause your lowering the center of gravity...if you use springs w/ the stock struts you will eventually most likely blow the struts. If you go w/ coilovers your spring rate will most likely be stiffer then stock and the ride will become harsher depending on adjustability and how you have the coilovers set up. Its a give and take situation. If your going for looks mostly...go w/ swift springs and call it a day.
#39
#40
WOW your car is low bro!!!
it's way too low to me ,but everybody is different !
i like how clean your car is! goog job keeping up with a tb
thanks alot for the pics!
#42
is there any coilover out there is compareable to the stocks onces or near it ,,
in handleing wise,,,
thanks
#44
#45
