Stealth Evo Front attempt...
Originally posted by 2Cool
Normally they are painted with a very thin coat of paint thats actually designed for use on a radiator, but even then it slightly decreases efficiency. OEM radiators that come painted black are done that way for one main reason... corrosion prevention. Its the lesser of evils to prevent corrosion at the expense of some lost efficiency. But if you notice, most performance radiators are bare metal, and even the emblemed example is only a rather small area of the total cooling area, which doubtless deems worthwhile for the advertising it provides.
If you want to actually see proof of this, how about a nice mathematical description of the effect of a screen on airflow, with the size of the mesh opening related to backpressure and velocity: Air Flow
Actually... I just looked at the results again, and it appears that the last 3 sizes have about the same results. It is only when they get into the really small meshes that there is a change...
So, would one conclude that if you have anything bigger it will not really matter, well, at 70cfm anyway? Am I intrepreting the results correctly?
Admin Emeritus
I was there at xtnct's as "technical assistant" today. Which means he painted and I drank beer. I felt the mesh would make a significant reduction in airflow, but without measurements and calculations my arguement was intuitive only.
BTW for those who like the agressive look of the intercooler...... I tried to stop him.
Speedlimit...
Speedlimit...
Oh the poor thing . FMIC's are beautiful; I just don't understand it. Darker colors are heat absorbers and lighter colors are heat reflecters when dealing with sunlight. The black will definitely not transfer heat as efficiently. Also, ANY coating of paint will act as an insulation, no matter how slight. Each of those tiny little aluminum fins are now wearing a nice little black winter coat for the love of god when really all they wanted was to be naked on a cold, cold day .
Admin Emeritus
I took a look at the technical paper and the free hole area appears to be the limiting variable relative to flow. And it doesn't seem to make a big difference whether the area is reduced by a larger diameter mesh or a higher mesh density. Either way there will be "choke flow" point and flow will decrease and pressure drop will increase accross the mesh.
Since the only thing we car about is intercooler heat transfer, a good baseline run with the road-dyno would have been nice as a comparison before and after the mesh.
Speedlimit..
Speedlimit..
actually, black is usually the coolest color for anything to be out of direct sunlight or heat radiation source. it radiates the most heat away. the problem is that now it will absorb more radiated heat from the engine (though the radiator would probably catch most of that). in addition, you just ruined the transfer coeffecient, as paint will not transfer heat as fast as bare metal... to prove this go open your freezer and touch a plastic or coated part, and touch a bare metal part. I bet the metal one feels colder.. actually everything is the same temp, just the metal transfers heat away from your hand faster. now how much an effect this will have on the real world is unknown, and probably barely noticable, but in theory you're hurting the cooling ablility of the IC... but on the other hand, it does look nice, and i'm considering putting a smaller screen just toblock insects ad rocks that are completely killing my IC.
What a dumbass . . . painting the intercooler black.
Black absorbs heat like crazy.
Wear a black jacket out on a sunny hot day
Then wear a white or silver jacket.
I guarantee you wearing the black jacket will make you feel much hotter. Your Intercooler needs to be cool not hot.
Also as the others said, painting the intercooler reduces the heat transfer efficiency due to the paint.
Black Intercooler
I think it looks good. I agree with not wanting to advertise also.
What type of paint did you use or did you anodize?
I disagree with the guys that are stating that it reduces efficiency. I doubt that radiators would be this color if it dramatically affected cooling. Cobb tuning/APS sells a black intercooler as do some other manufacturers
The fact is...
The paint will insulate and block air flow.
Bad idea.
Strip it and get it black anodized if it is that important to you.
A hot dog wrapper on a radiator can make a race car overheat!
Don't under estimate the importance of air flow.
It is funny how some guys hand tweezer the bugs out every week and other guys will paint them black
Bad idea.
Black IC
Originally posted by skibum
The fact is...
Bad idea.
The fact is...
Bad idea.
It won't block airflow as long as he sprayed from an acute angle on the horizontal plane. This will stop paint coating the inner part of the IC fins. I did it this way on my Integra intercooler on some advice from the honda forums back in the day.
