Stealth Evo Front attempt...
Well, I painted my IC black. I really like it. Just for kicks, I also installed regular screen door mesh in front of the mesh parts on the front end. I can't decide if I like it or not. From far away, it looks kinds neat, from up close, kinda cheap. I may rip it out...not sure yet. Here are some before and after pics (not very good):
BEFORE:
![](http://www.jgajewski.org/evo/myevo.jpg)
AFTER:
![](http://www.jgajewski.org/evo/stealthevofront.jpg)
![](http://www.jgajewski.org/evo/stealthevofront2.jpg)
BEFORE:
AFTER:
![](http://www.jgajewski.org/evo/stealthevofront3.jpg)
i think it looks pretty cool! i liek it, specially since u cant see the intercooler so alot of peopel that dont know the evo wont knwo its turbo and will be shocked after they get there asses handed to them!
Very nice look... the black FMIC especially. I think the screen may be too fine and restrict air flow too much, but time will tell I guess. If it doesn't restrict air flow or hamper performance at all, then it will definitely help protect that soft metal in the long run.... good deal, dude.
-N
-N
Originally posted by 2Cool
Watch your air temps... that small an opening screen will have an effect on airflow.
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
I could argue hypothetically, that the screen mesh will actually prevent insects from lodging inside the IC & rad, and prevent road debris from bending the slits, thereby maintaining maximum flow at all times and increase cooling effciency.
But yeah, I was planning on keeping an eye on things, just to make sure.
![](http://www.jgajewski.org/evo/bugonmesh.jpg)
I think you guys are using some bad analogies there... how about this one... ever stand on a screen porch on a hot day, watching the slight breeze moving the tree leaves, yet feeling hardly any air moving inside? Ever see an OEM installed screen over the radiator on any vehicle? Theres a reason for it, it will and does effect airflow. If you run a thermistor under the hood, you will see a difference. I prefer to let my intercooler breathe, not choking it off with a screen or paint, but its your call for your own car...
If you want to actually see proof of this, how about a nice mathematical description of the effect of a screen on airflow, with the size of the mesh opening related to backpressure and velocity: Air Flow
Did you use the regualr black mesh screen or aluminum painted black?? I would opt for aluminum for durability sake... I've been thinking about doing the IC section with a layer of aluminum screen to keep the bugs and rocks out of the fins...
Doesn't painting the IC reduce the heat transfer??
Looks real nice
Looks real nice
![HeadBang](https://www.evolutionm.net/forums/images/smilies/headbang2.gif)
I'd do the experiment to settle this once and for all, but I lack one piece of equipment (the speedometer on bike). If any of you have all the required items to perform an experiment, please do so. I'm really curious what the results are.
ITEMS:
1. 20" fan or similar (more than one stting would be nice)
2. some screen door mesh (or take it out of your door)
3. bicycle with a speedometer
4. old deck of cards (or similar)
5. stopwatch
PROCEDURE:
- place the bike upside down say 3" in front of fan
- place a few cards in the spokes (like when you were a kid) to catch some of the air to make the wheel spin)
- turn fan on
- wait till you get a constant speed on the speedometer. Make sure the speed is constant for say about 30 seconds
- place the screen mesh between fan and bike (make sure you do not change the distance between bike and fan)
- wait for a new constant speed, note the speed change if ANY
- reapet above for each of the sttings on fan
Don't hypothesize, prove it!
If anyone has access to better tools/methods, be my guest.
ITEMS:
5. stopwatch
PROCEDURE:
- turn fan on
Originally posted by Ibiza013
cool, now you lost some intercooler efficiency by spray painting it black.
![Thumb Up](https://www.evolutionm.net/forums/images/smilies/icon14.gif)
Why was the top of the IC already painted black from the factory? (go check your car)
Why did mitsu paint the oil cooler black then? (go check your car)
Why somone (mitsu team?) paint their red diamonds on a rally car IC if it decreases performance (pic in this thread: https://www.evolutionm.net/forums/sh...ooler+painting)
Why did my NEW aftermarket radiator (for another car) come painted black then? (sorry, don't feel like digging up the pic)
Normally they are painted with a very thin coat of paint thats actually designed for use on a radiator, but even then it slightly decreases efficiency. OEM radiators that come painted black are done that way for one main reason... corrosion prevention. Its the lesser of evils to prevent corrosion at the expense of some lost efficiency. But if you notice, most performance radiators are bare metal, and even the
emblemed example is only a rather small area of the total cooling area, which
doubtless deems worthwhile for the advertising it provides.
![Mitsubishi Logo](https://www.evolutionm.net/forums/images/smilies/mitsu_logo.gif)
