Carbon Fiber Trunk Spring?
#31
I noticed the trunk warping after about a month. It was fine for a while. You may want to do something about it before it does become a problem.
#33
#34
Has anyone tried to dremmel relief cuts into the stock MR springs? I think I might try it this weekend. I figure cut into the trunk spring where they attach to the arms of the trunk, to reduce their strength. I'll let you guys know if I lose an eye or something.
#35
Hey guys, quick question. I'm in the process of installing my carbon fiber trunk and only plan on using the interior release to open/close it. Due to its lower weight it now flings itself open with the force of a 11th century trebuchet
I'd like to not have a potentially lethal trunk opening, however appealing the idea of a potato launching trunk is. So what are my options? Is there a way to adjust the spring force on the stock unit? Would getting an evo RS spring help/ be cost effective? Does anyone sell a kit to help reduce this at all?
Thanks for the help guys.
#36
How do you go about removing the trunk springs? Its not working for me no matter what I try...
edit, to take off the springs all you do is take a channel lock plier and grab the rear most piece of the U and pry in a downward position leveraging it against the other side of the U and it should come off...
GSX_TO_EVO
Jul 26, 2016 11:13 AM
wprettyboy
17
Jan 23, 2006 02:17 PM
