20psiMR's Graphite Gray MR with Advan RS's
No rolling done. Only rubbed when I had a full car full of people driving down to MOD, and only when I was going above 40mph in turns like freeway onramps, etc.
Doesnt rub EVER when its just me in the car. Course your mileage may vary, it all depends on the tires you get. Some brands are wider then others even though they are the same size.
Tint is 15% all the way around, regular black with slight metallic.
Alignment specs are -1.5 camber front, -1 rear. 0 Toe up front, +.05 in the rear. Basically stock settings, but had it checked after spring install and new wheels were on.
