wax the headlights?
Old Aug 11, 2007 | 09:10 AM
diviniti's Avatar
I personally never wax mine. I do however use RainX on them, along with the window. Usually 3-4 coats. Nothing will stick to either surface for awhile.
Old Aug 24, 2007 | 10:19 AM
evo8426's Avatar
+1 thats what i do
Old Aug 24, 2007 | 01:04 PM
donbrown34567's Avatar
ive waxed my headlights, taillights, and windows (not the windshield) and i havent had any problems so far
Old Aug 24, 2007 | 01:17 PM
donmeca2020's Avatar
i been wanting to try that plastix from meguairs i have a few lil scratches on one of my headlights.
Old Aug 24, 2007 | 01:20 PM
EvoEntropy's Avatar
I wax everythign except the windsheild and rear window, then i go over the headlights and taillights and the mitsu diamonds with windex and the windows with rainx
Old Aug 24, 2007 | 02:32 PM
theblue's Avatar
don't use rainX on plastic, it eats it.
don't wax windows because it's not optically clear and won't really do much
don't wax any plastic - if you do and it doesn't look like crap then your wax sucks in general
plastix is good for any clear plastics.
Old Aug 24, 2007 | 02:59 PM
[Neo]'s Avatar
My lights look like theyve been sand blasted-yellowish...will plastix help this?
Old Aug 24, 2007 | 03:15 PM
SoCalRedLine's Avatar
you would want to use a plastic specific polish. wax doesnt polish anything, it only seals up.
in general, when you paint somthing you do this:
Paint
wet sand out the 'orange peel' and imperfecions
polish to a shine
wax to seal
too many people think that waxing is polishing...you can apply wax to your car anytime, but polishing your car is what makes the paint shine...
fwiw...
i havent used plastix, but have heard good things about it from others that used it to smooth out a bad Niteshade job.
Old Aug 24, 2007 | 03:42 PM
incog6's Avatar
Wax your headlights/taillights often to prevent oxidation.
Polish your headlights/taillights ONLY if they're oxidized. The reason I say this is because polishing actually is removing a small lair of plastic to make it smooth. If your lights aren't oxidized and you decide to polish them, you're removing a part of the protective lair.
This is what oxidized headlights look like: http://www.autodetailingsolutions.co...ightBefore.jpg.
Old Aug 24, 2007 | 05:44 PM
[Neo]'s Avatar
yeah mine are starting to look like that but not that bad...I dont want them to be that bad!
I tried rubbing compound but that didnt work...what polishes plastic? i need to go to pepboys...
Old Aug 24, 2007 | 07:02 PM
incog6's Avatar
If you have a orbital polisher, it will make things easier. The general rule of thumb is to start off with the least aggressive polish (and polishing pad, if applicable), check the results, and if it needs something more aggressive, move up. If the oxidation is really bad, you might have to start moving into the fine grit sandpaper (1000+) with water (aka wet sanding).
Old Oct 3, 2008 | 11:54 AM
Quesadilla's Avatar
I just toothpasted my drivers side headlight. Looks awesome, you'd really have to look to know it was foggy at all.
Old Oct 3, 2008 | 12:24 PM
Billy@EnglishRacing's Avatar
plastX works well
Old Oct 5, 2008 | 09:04 AM
boostedwrx's Avatar
You should really buff them first then wax them. And yea don't use Rain-X on them but any wax is fine on them.
CottageLifer
Outlander Sport
Aug 11, 2019 03:20 AM
Paulevo9
Sep 22, 2015 11:18 AM
lanevokai
Aug 31, 2006 12:45 PM
Ravenlancer
May 9, 2004 08:27 PM
