wax the headlights?
wax the headlights?
I'm getting ready to wax the Evo and was wondering if I should apply wax to the head and rear lights? Does the wax shine the plastic or dull it?
I wax windows and headlight and tail light lens. What kind of plastic do you use wax on? I've had bad experience using wax on non clear plastic in the past so I'm hesitant to use it on anything other than lens.
good luck getting them apart and back together. If you manage to do it, they will probably fog like crazy. See the ricer foggy headlights/tailights? That is because they are poorly made and sealed.
it is the same procedure used to paint the headlights. as long as you take your time, follow the threads in the how to section, and use a good sealant, you wont have any problems.
