Finally installed everything
I received my car back last Friday with all of it's new found little goodies and it turned out very good I think. I will be getting it dyno'd in a few weeks as well and I will post the #'s when I do.
As for the parts that I had installed, I went with the GSC S1 Cams, ARP head studs, Double Springs and Ti retainers, Walbro 255 Fuel Pump, Buschur test-pipe and Cat-back exhaust and the new Megan Down-pipe, Nisei Comp IC with all of the piping, Nisei mini-battery kit, Forge MBC, K&N Drop-in Filter, auto-meter Boost gauge and a custom tune/road tune by James Reese of Reese Tuning. James was able to tune my car all the way to 24 psi on crappy 91 with no Knock and great AFR's, but we decided to go with 22-23 psi for the final tune.
Here are some pics:
Nisei IC
Boost Gauge
Exhaust
Mini-battery, UICP, Forge MBC
Here are some pics:
Nisei IC
Boost Gauge
Exhaust
Thanks!
You can read minds! lol, your absolutely correct, in fact I am planing on the turbo swap to start around early December.
Thanks, I'm hoping for some good numbers as well!
That is the Nisei UICP.
Yes, James Reese of Reese Tuning did all of the install + Tune. His shops grand opening is coming up later this month I believe.
It is definitely a blast to drive!
