Installed Hallman In-Cabin MBC
I got this from MO_EVO8 here on the board. Came just like he said, bnib. Took several hours to install, mainly because the cable that comes with it, simply wont bend at all. I do have a recommendation for others. That cable is VERY durable, but if you want the cable to easily bend around in tight corners... simply use a hacksaw & cut the hard plastic covering around the metal wire. Then use a bigger vacuum hose & slip it over. It will work like cake.
On to the pictures...
I've been debating doing this. In the late fall and early spring it sucks to have to pop the hood and turn the boost down in the chilly morning then turn it back up after work when it is warm out. I have seen 3psi differences from when I am on my way to or from work.
